DIR-615/FB/O1EOL EOS
Wireless N300 Router with Fiber WAN Port
Kur iegādāties
Apraksts
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Configuration and Management
You can configure and manage the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in several languages).
Īpašības
Hardware
WAN Interface
• 1 10/100Mbps SFP port for fiber optic connector
LAN Interface
• 4 10/100BASE-TX Ethernet ports
WLAN Interface
• IEEE 802.11n (up to 300Mbps)
• IEEE 802.11b/g
Software
Network Functions
• WAN connection types
   • PPPoE
   • Static IP
   • Dynamic IP
   • PPTP/L2TP
   • PPTP/L2TP + Static IP
   • PPTP/L2TP + Dynamic IP
• DHCP server and client
• DNS relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• Support of VLAN
• WAN ping respond
Wireless Connection
• Supported security settings
  • WEP
  • WPA/WPA2 Personal
  • WPA/WPA2 Enterprise
• MAC filter
• Managing connected stations
• Advanced settings
• WMM (Wi-Fi QoS)
• Support of client mode
Firewall Functions
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Automatic synchronization of system time with NTP server
• Traceroute utility
Fiziskie raksturlielumi
LEDs
• POWER
• LAN 1-4
• WLAN
• WPS
• SFP
Power
• External power adapter
Buttons
• ON/OFF power switch
• Reset to Factory Defaults button
Operating Temperature
• From 0° to 40°C
Storage Temperature
• From -20° to 65°С
Operating Humidity
• From 10% to 90% non-condensing
Storage Humidity
• From 5% to 95% non-condensing
Sertifikāti
Informācija pasūtījumam
DIR-615/FB/O1 Wireless N300 Router with Fiber WAN Port
Attēli
DIR-615/FB/O1
Skatiet arī
