Ātrā meklēšana
Produkta iespējas:
Bezvadu divu frekvenču 802.11n standarta maršrutētājs ar 4 Gigabit portu komutatoru, līdz 450 Mb/s
EOL
Īpašības:
Standarti:
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.3
  • IEEE 802.3u
  • IEEE 802.3ab
WAN savienojuma veidi:
  • Static IP
  • Dynamic IP
  • PPPoE
  • PPTP
  • L2TP
Interfeiss ar lietotāju:
  • 4 10/100/1000Base-T Gigabit LAN porti
  • 1 10/100/1000Base-T Gigabit WAN ports
  • 1 USB 2.0 ports
Antenas:
  • 3 noņemamas divu frekvenču antenas ar SMA savienojumiem
Bezvadu savienojuma ātrums1:
  • IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • IEEE 802.11b: 1, 2, 5.5, 11 Mbps
  • IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • IEEE 802.11n (2.4 GHz): no 6.5 līdz300 Mbps
  • IEEE 802.11n (5 GHz): no 6.5 līdz450 Mbps
Raidītāja jauda:
  • IEEE 802.11a:
  • 19 dBm - 6-36 Mbps
  • 18 dBm - 48 Mbps
  • 16 dBm - 54 Mbps
  • IEEE 802.11b:
  • 20 dBm - 1, 2, 5.5, 11 Mbps
  • IEEE 802.11g:
  • 20 dBm - 6-36 Mbps
  • 19 dBm - 48 Mbps
  • 18 dBm - 54 Mbps
  • IEEE 802.11n, 2.4 GHz, HT20:
  • 20 dBm – MCS0-MCS4, MCS8-MCS12
  • 19 dBm – MCS5, MCS13
  • 18 dBm – MCS6, MCS14
  • 17 dBm – MCS7, MCS15
  • IEEE 802.11n, 2.4 GHz, HT40:
  • 19 dBm – MCS0-MCS5, MCS12-MCS13
  • 16 dBm – MCS7, MCS15
  • IEEE 802.11n, 5 GHz, HT20:
  • 19 dBm – MCS0-MCS3, MCS8-MCS11, MCS16-19
  • 18 dBm – MCS4-MCS6, MCS12-MCS14, MCS20-MCS21
  • 17 dBm – MCS22
  • 14 dBm – MCS23
  • IEEE 802.11n, 5 GHz, HT40:
  • 18 dBm – MCS4-MCS5, MCS12-MCS13, MCS20-MCS21
  • 17 dBm – MCS6, MCS14
  • 16 dBm – MCS7, MCS15, MCS22
  • 13 dBm – MCS23
Uztvērēja jutība:
  • IEEE 802.11a:
  • -82 dBm – 6 Mbps
  • -81 dBm – 9 Mbps
  • -79 dBm – 12 Mbps
  • -77 dBm – 18 Mbps
  • -74 dBm – 24 Mbps
  • -70 dBm – 36 Mbps
  • -66 dBm – 48 Mbps
  • -65 dBm – 54 Mbps
  • IEEE 802.11b:
  • -87 dBm – 1 Mbps
  • -87 dBm – 2 Mbps
  • -85 dBm – 5.5 Mbps
  • -82 dBm – 11 Mbps
  • IEEE 802.11g:
  • -82 dBm – 6 Mbps
  • -81 dBm – 9 Mbps
  • -79 dBm – 12 Mbps
  • -77 dBm – 18 Mbps
  • -74 dBm – 24 Mbps
  • -70 dBm – 36 Mbps
  • -66 dBm – 48 Mbps
  • -65 dBm – 54 Mbps
  • -82 dBm – MCS0/8
  • -79 dBm – MCS1/9
  • -77 dBm – MCS2/10
  • -74 dBm – MCS3/11
  • -70 dBm – MCS4/12
  • -66 dBm – MCS5/13
  • -62 dBm – MCS6/14
  • -64 dBm – MCS7/15
  • -79 dBm – MCS0/8
  • -76 dBm – MCS1/9
  • -74 dBm – MCS2/10
  • -74 dBm – MCS3/11
  • -67 dBm – MCS4/12
  • -63 dBm – MCS5/13
  • -65 dBm – MCS6/14
  • -61 dBm – MCS7/15
  • -82 dBm – MCS0/8/16
  • -79 dBm – MCS1/9/17
  • -77 dBm – MCS2/10/18
  • -74 dBm – MCS3/11/19
  • -70 dBm – MCS4/12/20
  • -66 dBm – MCS5/13/21
  • -65 dBm – MCS6/14/22
  • -64 dBm – MCS7/15/23
  • -79 dBm – MCS0/8/16
  • -76 dBm – MCS1/9/17
  • -74 dBm – MCS2/10/18
  • -67 dBm – MCS4/12/20
  • -63 dBm – MCS5/13/21
  • -62 dBm – MCS6/14/22
  • -61 dBm – MCS7/15/23
Drošība:
  • WPA un WPA2
  • 64/128 bitu WEP šifrēšana
  • Wi-Fi Protected Setup (WPS) – PIN un PBC
Ierīces vadība:
  • Internet Explorer 6+, Mozilla Firefox v1.5+,jaunākas versijas vai cita pārlūkprogramma ar Java atbalstu
  • D-Link Network Monitor Yahoo! Widget
  • D-Link Internet Usage Meter Yahoo! Widget
  • DLNA serveris, kas plūsmas media datus pārraida uz saderīgiem media atskaņotājiem6
Funkcijas SharePort Plus atbalsts:
  • Iespēja USB portam pieslēgt ārējo cieto disku vai daudzfunkcionālo ierīci
  • Iespēja kopīgi izmantot cieto disku, drukāšanas un skenēšanas funkcijas5
QoS:
  • D-Link Intelligent QoS tehnoloģija
Ugunsmūra funkcijas:
  • Network Address translation (NAT)
  • IP/MAC adrešu filtrēšana
  • VPN Pass-through / Multi-sessions PPTP / L2TP / IPSec
  • DMZ zona
Maršrutētāja funkcijas:
  • Port Forwarding
  • Port Triggering/ īpašu aplikāciju atbalsts
  • Statisko maršrutu atbalsts
  • WLAN Partition atbalsts
  • DHCP serveris
  • DNS relay
Minimālās sistēmas prasības:
  • Operētājsistēma: Windows 7/Vista3/ XP SP3 vai MAC OS X (v10.4)4
  • Pārlūkprogrammas: Internet Explorer 6, Firefox 1.5 vai jaunākas versijas
  • CD-ROM
  • Ethernet tīkla interfeiss
  • Kabeļa vai DSL modems
  • Līgums ar interneta pakalpojumu sniedzēju
Fiziskie raksturlielumi
Ieejas spriegums:
  • 12 V, līdzstrāva, 2 A
Strāvas patēriņš:
  • Līdz 18 W
Temperatūra:
  • Darba: 0º ÷ 40º C
  • Uzglabāšanas: -20º ÷ 65º C
Mitrums:
  • Darba vidē: nuo 10% iki 90% (bez kondensāta)
  • Uzglabāšanas vidē: nuo 5% iki 95% (bez kondensāta)
Izmēri:
  • 198 x 120.5 x 32.5 mm
Svars:
  • 370 g
Sertifikati:
  • FCC Class B
  • IC
  • IPv6 Ready
  • Wi-Fi Certified
  • CE Class B
  • C-Tick
  • LVD
  • RoHS compliant
  • Windows 7
1Maksimālais bezvadu datu pārraides ātrums ir noteikts 802.11g/a/n standarta specifikācijās. Reālais datu pārraides ātrums var atšķirties. To var ietekmēt vide, kurā darbojas tīkls, vides faktori (tīkla datu plūsmas apjoms, ēku būvmateriāli un konstrukcijas, tīkla darba dati u. tml.), kas var samazināt reālo datu plūsmas caurlaidību. Tīkla darbības rādiusu var ietekmēt arī vides faktori.
2Gigabit ātruma maršrutizēšanu atbalsta tikai ar Static IP vai DHCP caur WAN un tikai ar RCP savienojumiem.
3Datoram ir jāatbilst Microsoft ieteiktajām prasībām.
4 Programmatūra, kas ietilpst maršrutētāja komplektā, nav savienojama ar MAC OS.
5Konkrētā brīdī tikai vienam lietotājam ir piekļuve cietajam diskam vai daudzfunkcionālajām ierīcēm.
6Kompānija D-Link negarantē pilnīgu saderību un korektu darbību ar visiem kodekiem. Datu atjaunināšana ir atkarīga no DLNA media atskaņotāju kodekiem.
Visi dati par datu pārraides ātrumu ir norādīti tikai salīdzināšanas nolūkos. Ierīces specifikācijas, izmēri un ārējais izskats var tikt mainīti bez iepriekšēja brīdinājuma. Ierīces ārējais izskats var atšķirties no šeit attēlotā.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
