DAS-4192-20EOL
ADSL2+ Line Card, 48 ports
Apraksts
Linear module for the DAS-4192. This module supports 48 ADSL2 / 2 + ports, which allows connecting up to 48 ADSL users.
Īpašības
Interface
• 48 ports
Line standarts
• ANSI T1.413
• ITU-T G.992.1, (G.dmt) AnnexA
• ITU-T G.992.2, (G.Lite) AnnexA
• ITU-T G.994.1, (G.hs) handshake protocol
• ITU-T G.992.3, (ADSL2)
• ITU-T G.992.3, AnnexM
• ITU-T G.992.3, AnnexL (Reach Extended xDSL)
• ITU-T G.992.5, (ADSL2+)
ATM
• 8 PVC (port)
• OAM loopback
• RFC 2684 (Multiple Protocol over AAL5)
Power Consumption
• Full load: 49 W
• Subscriber port: 1.02 W
Dimensions
• 400 х 24.1 х 255.1mm
Weight
• 0.95 kg
Sertifikāti
Informācija pasūtījumam
DAS-4192-20 ADSL2+ Line Card, 48 ports
