SP-206E
ADSL2+ Annex B splitter with 10 cm phone cable
Kur iegādāties
Apraksts
The SP-206E splitter is a low frequency filter and it is intended for dividing low frequency telephony signal (voice signal spectrum) and high frequency ADSL signal. The SP-206E is placed at the phone line input (before phone connection). Thus, using the splitter excludes interference of modem and phone signals, providing concurrent operation of the devices. This splitter is equipped with the elements protecting the device against impulse over voltage and crosstalk. ADSL, ADSL2, ADSL2+ Annex B standards are supported.
Īpašības
Interfaces
• One RJ-11 connector for a phone line
• One RJ-11 connector for a phone (or mini-PBX)
• One RJ-11 connector for a ADSL modem
Standards
• ADSL, ADSL2, ADSL2+ Annex B
Dimensions (L x W x H)
• 60 x 44 x 23.5 mm
Operating temperature
• 5 to 40 °C
Storage temperature
• -20 to 85 °C
Operating humidity
• 5% to 85%
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
SP-206E  ADSL2+ Annex B splitter with 10 cm phone cable
Attēli
SP-206E
Вид снизу
Вид сзади
Вид справа
Вид сверху
Skatiet arī
