SP-320-48SMEOL
External power supply for DAS-4192, 321.6W
Apraksts
The SP-320-48SM external power supply is ideal for applying with the DAS-4192 IP DSLAM D-Link, providing the necessary parameters for operation of the DAS-4192.
SP-320-48SM supports the following nominal values of characteristics: 321.6W output power, 6.7A output current and 48V output voltage. In addition, the device provides built-in protection mechanisms against overload, output voltage exceedence, short circuit and high temperatures.
Īpašības
Built-in protective mechanisms
• Overload protection is triggered when the output power exceeds the nominal value of 5%-35%
• Protection against the output voltage exceedance and short-circuit is triggered when the output voltage is from 57.6V to 67.2
• Protection against high temperatures
Ventilation
• Built-in DC fan
• Fan speed control
Sertifikāti
Informācija pasūtījumam
SP-320-48SM  External power supply for DAS-4192, 321.6W
Attēli
SP-320-48SM SP-320-48SM
View from the right
Pārlādēt
Skatiet arī
