Ātrā meklēšana
Produkta iespējas:
OUTDOOR OMNI-DIRECTIONAL ANTENNA
Īpašības:
FREQUENCY RANGE
2.4GHz to 2.5GHz
STANDARDS
+ IEEE 802.11g
+ IEEE 802.11b
IMPEDENCE
50 Ohm (nominal)
VSWR
1.92:1 (maximum)
RADIATION
Omni-directional
POLARIZATION
Linear vertical
HPBW/HORIZONTAL
360˚
HPBW/VERTICAL
PEAK GAIN
12dBI typical
RADOME COLOR
White
EXTENSION CABLE
N-Plug to RP-SMA Plug
ANTENNA CONNECTOR
N-Jack (female)
EXTENSION CABLE LENGTH
50 cm (0.5 m)
DIMENSIONS
1718 x 48 mm (67.64 x 1.89 inches)
WEIGHT
1.2 kg
OPERATING TEMPERATURE
-40˚ to 80˚C
STORAGE TEMPERATURE
-40˚ to 80˚C
OPERATING HUMIDITY
90% at 25°C
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
