DAP-3340EOL EOS
Outdoor Wireless N300 Access Point with PoE Support
Kur iegādāties
Apraksts
The D-Link DAP-3340 Outdoor Wireless N300 Access Point with PoE support is an ideal solution for creating hotspot zones, which provide access to Internet for users located outside the building. This multifunctional access point with high transmit power and excellent weather resistance features is suitable for installation in factories, industrial complexes, in conference rooms, college campuses, airports, golf clubs, river stations and other public places.
Multifunctionality
DAP-3340 will allow network administrators to create a manageable and reliable wireless 802.11n network. The supplied antennas are detachable and provide optimal wireless coverage in the frequency range of 2.4GHz (802.11g and 802.11n), using a high power transmitter to reduce Dead Spots and increase capacity. This high-speed access point supports standard 802.3af Power over Ethernet (PoE), making it easy to install the device in areas where power outlets are not available.
Safety
In order to secure the wireless network DAP-3340 supports both Personal and Enterprise versions of WPA and WPA2 (802.11i) with RADIUS server. In addition, the access point supports MAC address filtering, wireless LAN segmentation, Disable Broadcast SSID, the detection of unauthorized access points and wireless network performance in Broadcast Scheduling. DAP-3340 supports up to eight VLAN, which allows multiple SSID to segment users on the network. Also implemented in the access point wireless client isolation mechanism, which limits direct interaction such as "client-client."
Operation modes
DAP-3340 Access Point can be configured in one of the following modes: Access Point, Wireless Client, Wireless Distribution System (WDS), and WDS with AP. With WDS support, network administrators can install multiple DAP-3340 access points and configure them to work with each other in bridge mode, while providing network access to individual clients. In addition, Spanning Tree Protocol support promotes a more efficient transfer of traffic and allows to avoid broadcast storms when used in WDS mode.
Network management
Network administrators have several options for managing the DAP-3340 access point, which include Web-based (HTTP), Secure Sockets Layer (SSL, which provides a secure connection to the Internet), Secure Shell (SSH, which provides a secure channel between local and remote computers), and Telnet. For advanced network management, administrators can use D-Link AP Manager II or the SNMPv3 D-View control module, to configure and manage multiple access points from a single computer. In addition, AP Manager II or D-View allows network administrators to remotely perform the inspection of the equipment, eliminating the need for direct personal control over any operations.
Īpašības
Features
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.3ab
• IEEE 802.3af
• IEEE 802.3u
• IEEE 802.3
Network management
• Telnet - Secure (SSH) Telnet
• Web-interface
• HTTP - Secure HTTP (HTTPS)
• Support for SNMP
• The D-View - Private MIB
• AP Manager II
• AP Array
Security
• WPA™-Personal
• WPA-Enterprise
• WPA2™-Personal
• WPA2-Enterprise
• 64/128-bit WEP
• Disable SSID Broadcast
• Access Control MAC-based
• Detection of rogue access points
Support for VLAN / SSID
• 802.1q/Supports up to to 8 SSID
Quality of Service (QoS)
• 4 priority queues
• Priority WMM
Frequency band
• From 2.4GHz to 2.4835GHz
Wireless speed
• 802.11b: 1, 2, 5.5, 11 Mbit/s
• 802.11g: 108, 54, 48, 36, 24, 18, 12, 9 and 6 Mbit/s
• 802.11n: up to 300 Mbit/s
Max. transmitter power
• 24 dBm @ 2.4GHz
The output power of the transmitter
• 802.11b:
  24 dBm at 1, 2, 5.5, 11 Mbit/s
• 802.11g:
  24 ±2dBm at 6-24 Mbit/s
  22 ±2dBm at 36 Mbit/s
  21 ±2dBm at 48 Mbit/s
  20 ±2dBm at 54 Mbit/s
• 802.11n:
  HT-20
  22 ±2dBm at MCS0~1
  21 ±2dBm at MCS2~3
  20 ±2dBm at MCS4
  19 ±2dBm at MCS5
  18 ±2dBm at MCS6
  17 ±2dBm at MCS7
  HT-40
  21 ±2dBm at MCS0~3
  20 ±2dBm at MCS4
  19 ±2dBm at MCS5
  18 ±2dBm at MCS6
  17 ±2dBm at MCS7
Receiver sensitivity
• 802.11b:
  -76 dBm at 1 Mbit/s
  -76 dBm at 2 Mbit/s
  -76 dBm at 5.5 Mbit/s
  -76 dBm at 11 Mbit/s
• 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbits/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• 802.11n:
  HT-20
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
HT-40
  -82 dBm at MCS0
  -79 dBm at MCS1
  -77 dBm at MCS2
  -74 dBm at MCS3
  -70 dBm at MCS4
  -66 dBm at MCS5
  -65 dBm at MCS6
  -64 dBm at MCS7
Operation modes
• Access Point (AP)
• WDS access point
• WDS/Bridge (No AP Broadcast)
• Wireless client
Antennas
• 2 detachable dipole antennas
• STD-N connector type
The gain of the dipole antenna
• 5 dBi for 2.4GHz
The maximum output power of the transmitter
• 23 dBm at 2.4GHz
LEDs
• Power
• LAN
• WLAN 2.4GHz
Fiziskie raksturlielumi
Operating temperature
• -40° To 50°C
Housing protection
• IP67
The maximum power consumption
• 9W with PoE
Operating voltage
• 48VDC +/-10% for PoE
Weight
• 1.62kg
Measurements
• 250 x 220 x 72.3mm
Sertifikāti
Informācija pasūtījumam
DAP-3340  Outdoor Wireless N300 Access Point with PoE Support
Attēli
DAP-3340/A1
Skatiet arī
