Ātrā meklēšana
Produkta iespējas:
Dual Polarization 2.4GHz Outdoor Directional Antenna
EOL EOS
Īpašības:
Frequency band
• From 2.4GHz to 2.5GHz
Resistance
• 50 Ohms
Gain
• 11dBi (2.4GHz)
VSWR
• 2.0: 1 (max)
The maximum gain
• 16-17dBi
Radiation pattern in the horizontal plane (HPBW/H-PLANE)
• 18°-25°
Radiation pattern in the vertical plane (HPBW/V-PLANE)
• 18°-25°
Polarization
• Linear, vertical/horizontal
The ratio of foreground and background signal levels (PZO)
• -25dB (max)
Cross-polarization isolation
• 16dB (minimum)
Fiziskie raksturlielumi
Cable
• 2 RP-SMA cable access points designed for indoor use
Jack
• Two N-type connector
Allowable power
• 6W (cw)
Lightning protection
• DC Ground
Wind load
• 216km/h
Operating temperature
• From -40°C to 80°C.
Operating humidity
• 95% at 55°C.
Colour and material
• Gray-white, PC UV resistant
Weight
• 1.1kg
Measurements
• 320 x 320 x 43mm
Impermeability
• IP67
Mount kit
• Pole mount and wall
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
