Ātrā meklēšana
Produkta iespējas:
Wireless N150 High-Gain USB Adapter
EOL EOS
Apraksts:
High-speed wireless networking
Connect to a high-speed wireless network with the D-Link Wireless N150 High-Gain USB Adapter and enjoy surfing the web, checking e-mail, and chatting with family and friends online. The DWA-127 uses Wireless N150 technology, which offers faster speeds and greater range than 802.11g/b,* providing you with a faster and more reliable wireless connection.
Enhanced wireless range
DWA-127 Wireless N150 High-Gain USB Adapter has a high-gain antenna that provides a boosted signal reception so that you can enjoy wireless coverage over a wider distance than with a regular wireless adapter. The antenna is also rotatable so you can eliminate dead spots by fine-tuning the antenna positioning to get the best available wireless connectivity.
Connect securely to your wireless network
To protect your data and maintain your privacy while surfing the web, the Wireless N150 High-Gain USB Adapter supports WEP, WPA and WPA2 encryption which enable you to connect to and access a secure wireless network. This allows you to securely shop and pay online and check e-mail with confidence.
Easy to install and connect
D-Link’s Quick Setup Wizard enables easy setup of your DWA-127 so you can get connected quickly. Wi-Fi Protected Setup (WPS) allows you to set up a secure wireless connection with just the push of a button. This eliminates the need for complicated configuration, thus simplifying setup and saving you time and hassle. The DWA-127 has a USB interface so it can be connected to both a notebook or a desktop computer.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
