DWA-525EOL
Wireless N 150 Desktop adapter
Kur iegādāties
Apraksts
High-speed wireless networking
Connect to a high-speed wireless network with the D-link Wireless N 150 Desktop Adapter and enjoy surfng the web, checking e-mail, and chatting with family and friends online. The DWA-525 uses Wireless N 150 technology, which offers increased speed and range over the 802.11g/b standard1 giving you a faster, more reliable wireless connection.
Connect securely to your wireless network
To protect your data and privacy, the Wireless N 150 Desktop Adapter supports WEP, WPA, and WPA2 encryption for connecting to a secure wireless network, keeping your network traffc secure.
Compatibilyty assurance
The Wireless N 150 Desktop Adapter provides a high-speed connection to other Wireless 802.11n devices and is backward compatible with 802.11g/b, ensuring compatibility with a wide range of wireless routers and networks.
Easy to install & connect
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a secure wireless connection, so all you have to do is push a button to automatically create a secure wireless connection to your network, doing away with the need for confguring complicated settings.
Īpašības
System requirements
Computer with:
+ Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
+ CD-rOM drive
+ 20MB hard disk space
+ Available USB port
Standards
+ IEEE 802.11n
+ IEEE 802.11g
+ IEEE 802.11b
Frequency range
2.4GHz to 2.4835GHz
Antenna
Detachable 2dBi dipole antenna
Security
+ 64/128-bit WEP data encryption
+ Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
+ Wi-Fi Protected Setup (WPS)
Data rates
+ 802.11n: up to 150 Mbps
+ 802.11g: 6/9/12/18/24/36/48/54 Mbps
+ 802.11b: 1/2/5.5/11 Mbps
O.S. Support
+ Windows XP/Vista and Windows 7
Diagnostic leds
Link/Activity
Fiziskie raksturlielumi
Operating voltage
5VDC +/- 5%
Dimensions (l x W x H)
122 x 120 x 22 mm (4.8 x 4.7 x 0.9 inches)
Operating temperature
0º to 40º C (32˚ to 104˚ F)
Storage temperature
-20º to 65º C (-4˚ to 149˚ F)
Operating humidity
10% to 90% non-condensing
Storage humidity
5% to 95% non-condensing
Certifications
+ CE
+ FCC Class B
+ C-Tick
+ IC
+ Wi-Fi
+ WPS Certifed
1 Maximum wireless signal rate derived from IEEE standard 802.11g specifcations. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffc, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Sertifikāti
Informācija pasūtījumam
DWA-525   Wireless N 150 Desktop adapter
Attēli
DWA-525/Ax
Вид справа
DWA-525/Bx
Skatiet arī
