DWA-525EOL EOS
Apraksts
High-speed wireless networking
Connect to a high-speed wireless network with the D-link Wireless N 150 Desktop Adapter and enjoy surfng the web, checking e-mail, and chatting with family and friends online. The DWA-525 uses Wireless N 150 technology, which offers increased speed and range over the 802.11g/b standard1 giving you a faster, more reliable wireless connection.
Connect securely to your wireless network
To protect your data and privacy, the Wireless N 150 Desktop Adapter supports WEP, WPA, and WPA2 encryption for connecting to a secure wireless network, keeping your network traffc secure.
Compatibilyty assurance
The Wireless N 150 Desktop Adapter provides a high-speed connection to other Wireless 802.11n devices and is backward compatible with 802.11g/b, ensuring compatibility with a wide range of wireless routers and networks.
Easy to install & connect
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a secure wireless connection, so all you have to do is push a button to automatically create a secure wireless connection to your network, doing away with the need for confguring complicated settings.
Īpašības
System requirements
Computer with:
+ Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
+ CD-rOM drive
+ 20MB hard disk space
+ Available USB port
Standards
+ IEEE 802.11n
+ IEEE 802.11g
+ IEEE 802.11b
Frequency range
2.4GHz to 2.4835GHz
Antenna
Detachable 2dBi dipole antenna
Security
+ 64/128-bit WEP data encryption
+ Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
+ Wi-Fi Protected Setup (WPS)
Data rates
+ 802.11n: up to 150 Mbps
+ 802.11g: 6/9/12/18/24/36/48/54 Mbps
+ 802.11b: 1/2/5.5/11 Mbps
O.S. Support
+ Windows XP/Vista and Windows 7
Diagnostic leds
Link/Activity
Sertifikāti
Informācija pasūtījumam
DWA-525 Wireless N 150 Desktop adapter
