DUB-1310
USB 3.0 to USB 3.1 Type-C Adapter
Kur iegādāties
Apraksts
The DUB-1310 adapter allows you to connect a device with USB Type-C connector to a device with USB 3.0 Type-A port. Simply connect the DUB-1310 to USB 3.0 port - the adapter is ready for use right after it is plugged in. The adapter’s compact design provides the convenience of its usage. USB 3.0 technology supports data rates of up to 5 Gbps. Thus, the DUB-1310 brings exceptional data rates and helps you to copy your video, music, photos and documents from one device to another. This adapter is backwards compatible with the USB 2.0 devices.
Īpašības
Interfaces
• USB Type-C port
• USB 3.0 Type-A connector
Standards
• USB 3.0
• USB 2.0
• USB 1.1
Data Rate
• Up to 5 Gbps
System Requirements
• Available USB 3.0 port*
• Windows, iOS, Android
Physical Parameters
Dimensions (L x W x H)
• 26 х 14 х 6.5 mm
Power Input
• From USB port of PC
Temperature
• Operating: -10 to 55 °C
• Storage: -20 to 85 °C
Humidity
• Operating: 10% to 85% non-condensing
• Storage: 5% to 90% non-condensing
* Using a USB 1.1 or USB 2.0 port will affect device performance. USB 3.0 port is recommended.
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DUB-1310  USB 3.0 to USB 3.1 Type-C Adapter
Attēli
DUB-1310/Bx
Вид сзади
Skatiet arī
