DCS-4701E
Vigilance HD Outdoor PoE Mini Bullet Camera
Kur iegādāties
Apraksts
The D-Link DCS-4701E Vigilance HD Outdoor PoE Mini Bullet Camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 1.3 megapixel progressive scan CMOS sensor to deliver truly superior quality video under a wide range of lighting conditions. The all-in-one rugged design makes this camera ideal for reliable deployment in surveillance applications without the need for additional accessories.
Enhanced LowLight+ Video
Incorporating a highly sensitive CMOS sensor, the DCS-4701E provides outstanding performance in low-light conditions, rendering more vibrant color details regardless of the amount of light available. The noise reduction feature has also been upgraded and enhanced as well to provide a level of detail in the image quality that is unmatched by other offerings in the market.
Continuous Monitoring
The built-in IR LED illuminators automatically turn on depending on lighting conditions, allowing the camera to capture video even in low-light or no-light conditions. Combined with the IR-Cut filter, the DCS-4701E can also provide sharp grayscale video in low-light conditions. Embedded with a powerful SoC (System-on-Chip), the camera provides real-time video compression in H.264 and MJPEG formats. These elements combine to make the DCS-4701E an ideal solution for 24-hour surveillance.
Convenient Connectivity
The DCS-4701E has a built-in 802.3af compliant PoE module that eases installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling.
Robust Management Software
The Vigilance HD Outdoor PoE Mini Bullet Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer from a central location. Recordings and e-mail alerts can be triggered through motion detection, keeping administrators informed of any unusual activity.
Īpašības
Camera
Camera Hardware Profile
•  1/3” 1.3 megapixel progressive CMOS sensor
•  30 meter IR illumination distance
•  Minimum illumination:
  •  0.2 lux (color)
  •  0.1 lux (B/W)
  •  0 lux (IR LED on )
•  Built-in Infrared-Cut Removable (ICR) Filter module
•  10x digital zoom
•  Minimum object distance 0.2 m
•  Focal length: 2.8 mm
•  Aperture: F2.0
•  Angle of view:
  •  (H) 96°
  •  (V) 54°
  •  (D) 108°
Camera Housing
•  IP-66 compliant weatherproof housing
•  Wire-in bracket
Image Features
•  Configurable image size, quality, frame rate, and bit rate
•  Time stamp and text overlays
•  Configurable motion detection windows
•  Configurable privacy mask zones
•  Configurable shutter speed, brightness, saturation, contrast, and sharpness
•  WDR
•  3D filter
Video Compression
•  Simultaneous H.264/MJPEG format compression
•  H.264/MJPEG multicast streaming
•  JPEG for still images
Video Resolution
•  16:9 - 1280 x 720, 800 x 448, 640 x 360, 480 x 272, 320 x 176 up to 30 fps
•  4:3 - 960 x 720, 800 x 592, 640 x 480, 480 x 352, 320 x 240 up to 30 fps
External Device Interface
•  10/100 BASE-TX Fast Ethernet port
•  Supports 802.3af PoE
Network
Network Protocols
•  IPv6
•  IPv4
•  TCP/IP
•  UDP
•  ICMP
•  DHCP client
•  NTP client (D-Link)
•  DNS client
•  DDNS client (D-Link)
•  SMTP client
•  FTP client
•  HTTP / HTTPS
•  Samba client
•  PPPoE
•  UPnP port forwarding
•  RTP / RTSP/ RTCP
•  IP filtering
•  QoS
•  CoS
•  Multicast
•  SNMP
•  ONVIF compliant
Security
•  Administrator and user group protection
•  Password authentication
•  HTTP and RTSP authentication
System Management
System Requirements for Web Interface
•  Browser: Internet Explorer, Firefox, or Safari
Event Management
•  Motion detection
•  Event notification and uploading of snapshots/video clips via e-mail or FTP
•  Supports multiple SMTP and FTP servers
•  Multiple event notifications
•  Multiple recording methods for easy backup
Remote Management
•  Take snapshots/video clips and save to local hard drive
•  Configuration interface accessible via web browser
D-ViewCam™ System Requirements
•  Operating System: Microsoft Windows 8/7/Vista
•  Protocol: Standard TCP/IP
•  Web Browser: Internet Explorer 7 or higher
D-ViewCam™ Software Functions
•  Supports all management functions provided in web interface
•  Remote management/control of up to 32 cameras
•  Viewing of up to 32 cameras on one screen
•  Scheduled motion triggered, or manual recording options
Weight
•  445 g ± 5 %
External Power Adapter
•  Input: 100 to 240 V AC, 50/60 Hz
•  Output: 12 V DC 1.5 A
Power Consumption
•  4.7 watts ± 5 % (PoE)
Temperature
•  Operating: -30 to 50 °C (-22 to 122 °F)
•  Storage: -20 to 70° C (-4° to 158° F)
Humidity
•  Operating: 20 % to 80 % non-condensing
•  Storage: 5 % to 95 % non-condensing
Certifications
•  CE
•  FCC
•  CE LVD
•  C-Tick
Dimensions
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
Attēli
DCS-4701E/Bx
Skatiet arī
