DCS-855LEOL EOS
Pan/Tilt Baby Camera
Kur iegādāties
Apraksts
Watch over your child anytime, anywhere with the DCS-855L Pan/Tilt Baby  Camera. Pan/tilt functionality lets you move the camera remotely; monitor an entire playroom with ease from your mobile device! With night vision, temperature monitoring, sound and motion detection, 2-way audio, notifications and more, the DCS-855L keeps you connected to your family.
Peace of Mind, Anywhere, Anytime
The Pan/Tilt Baby Camera is specially designed to make it easy for you to care for your baby. Its versatile all-day monitoring turns on night vision automatically when it gets dark, giving you a clear picture day or night so you can keep an eye on things anytime. Receive notifications when sound, motion, or a temperature change is detected. Not only can you see and hear your infant, but you can also comfort them with one of five gentle lullabies or even the sound of your voice through two-way audio.*
It’s perfect for use in the home, or even when you’re away; it’s mydlink-enabled, which means that you can access your camera remotely over the Internet on your PC or mobile device. Check on your baby while in the office, or check on the day’s events by playing back videos recorded to an installed microSD card.
Pan/Tilt for Corner to Corner Coverage
Unlike most baby monitors, the Pan/Tilt Baby Camera can pivot up, down, left, and right at your command, giving you the ability to watch over a large room effortlessly. Whisper quiet motors let you move the camera’s view without waking your sleeping child.
Perfectly Portable for Instant Monitoring Anywhere
You can take the Pan/Tilt Baby Camera with you when traveling with your child, even when there is no available Internet connection. Just connect your mobile device to the Pan/Tilt Baby Camera’s wireless network for instant local monitoring, making it perfect for family vacations or just visiting friends. You can even connect it to an external USB battery** for total portability.
Super Simple to Use
Getting started is a snap; the free mydlink Baby app for iPhone, iPad, and Android mobile devices not only guides you step by step through the setup process, but also gives you an easy to use interface for all the advanced features of the Pan/Tilt Baby Camera. Check on your baby at a glance, pinch to zoom in and out with ease, or play one of five gentle lullabies to soothe your child. You can even take snapshots and video clips and save them directly to your mobile device!
Īpašības
Camera Hardware Profile
• 1/4” Megapixel CMOS sensor
• Built-in Infrared-Cut Removable (ICR) Filter module
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in microphone and speaker
• Digital zoom
• Pan range: -170° to 170°
• Tilt range: -25° to 95°
• Focal length: 3.3 mm
• Minimum object distance: 200 mm
• Aperture: F2.2
• Angle of view:
  • (H) 70.4°
  • (V) 43°
  • (D) 84.6°
Connectivity
• 802.11 b/g/n wireless with WEP/WPA/WPA2 support
• Operates over the 2.4 GHz frequency band
• Single-band 1T1R mode supports a maximum data rate of 72.2 Mbps (PHY rate) using 20 MHz bandwidth
External Device Interfaces
• microSDHC card slot***
• Reset button
• Direct button
• Power port (Micro-USB)
LEDs
• PWR LED: Link/Activity/Power
• Cloud LED: Cloud/Direct Mode
Image Features
• Configurable image size
• Time stamp overlay
Video Compression
• H.264 format video compression
• JPEG for still images
Video Resolutions
• 1280 x 720 up to 30 fps
• 640 x 352 up to 15 fps
Audio Support
• AAC
• ADPCM
• 5 built-in lullabies
Baby Monitoring Features
• Sound detection with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Records snapshots and video to microSD when motion or sound is detected
• Temperature detection with configurable alert range
• Sends notifications when sound or motion is detected
• 2-way audio lets you listen and respond to your child
Mobile App
• mydlink Baby Camera Monitor app available on the App Store® and Google Play™
• Compatible with iPhone, iPad, or Android smartphones or tablets*
Network Protocols
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• HTTP
• HTTPS (for configuration)
• UPnP port forwarding
• RTP/RTSP/RTCP
Security
• Administrator protection
• Password authentication
• HTTP authentication
Fiziskie raksturlielumi
Dimensions
• 114.16 x 109.16 x 131.3 mm
Weight
• 396 g ± 5%
Power Input
• 5 V DC / 2 A, 50/60 Hz power adapter
• Can be powered by an external USB battery with at least 2 A output
Power Consumption
• 7.5 watts max. ± 5%
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC Class B
• ICES
• C-Tick
Dimensions
* Please refer to the mobile app’s store page to check whether your device is compatible.
** USB battery not included, requires at least 2 A output.
*** An SDHC Class 6 card or above is recommended. Supports card capacities up to 32GB.
Sertifikāti
Informācija pasūtījumam
Attēli
DCS-855L/Ax
Вид слева
Вид сзади
Вид слева
Skatiet arī
