DNR-312LEOL EOS
mydlink One-bay standalone NVR
Kur iegādāties
Apraksts
The DNR-312L mydlink One-bay standalone NVR is a standalone storage device that can record video from up to nine network cameras to its dedicated HDD storage* without requiring users to turn on their PC. Empowered by mydlink technology, the DNR-312L supports real-time remote monitoring and playback via a web browser using the mydlink website or the NVR’s web GUI. The DNR-312L has the ability to continue recording live while a user is viewing or searching footage at the same time. With complete video management, the DNR-312L’s display and playback ability make it a convenient and effective video recorder.
mydlink Technology on your Mobile Device
Empowered with mydlink technology, the DNR-312L enables users to  remotely view and manage mydlink enabled devices from anywhere via a web browser using the mydlink website or the NVR’s web interface. Additionally, using the mobile app means you can access and monitor your DNR-312L from your mobile devices.
Versatile Monitoring
Users are provided with a variety of options for viewing and organizing camera footage on-screen. For a system with multiple channels, users can simply drag and drop selected cameras to the viewing area. Camera names and recording statuses are displayed via the on-screen display. A single camera may be viewed full-screen with two-way audio support. Users can control pan/tilt/zoom (PTZ) functions from within the interface or by directly clicking on the video.
Secure Storage
Administrators may filter external connections to the NVR by IP address, limiting access and thus increasing security. Administrators may also choose access privileges for users by specifying the cameras they may access. The recorded data can be backed up to additional storage locations periodically or whenever needed.
Extensive Recording Functionality
The DNR-312L’s clear interface allows for easy configuration including compression, resolution, and frame rate for all connected cameras. Once the cameras have been set up, recordings can be made continuously, or according to a user-defined schedule. The NVR also provides event recording based on specific triggers such as when motion is detected.
Convenient and Reliable
The DNR-312L can manage multiple network cameras, providing direct access to view live video and play recorded data over the Internet from anywhere, anytime. Complete video management and the ability to playback and record new video simultaneously, the DNR-312L is an extremely convenient and effective video recorder. Moreover, the small size and portability of the DNR-312L make it easy to deploy in any location.
Bundled NVR Software
The NVR software bundled with the DNR-312L consists of five main components including a Playback Manager, a Backup System, and a very versatile search tool. The Playback Manager includes a clean and simple web GUI interface that allows users to play, search, or export video. The Backup System is a flexible backup utility that greatly simplifies the process of backing up video data from the NVR to external storage.
Īpašības
Standards
• IEEE 802.3/u/z
• Auto MDI/MDI-X
• SATA I, II, III
HDD
• Reformat Disk
• Up to 4TB HDD*
• EXT3 file system
Two Reset Modes
• Reset firmware GUI button
• HW reset button (hold for 10 seconds)
Reset Button
• Reset to factory default
Flash ROM
• 128 MB
RAM
• 1024MB DDR III
Network Interface
• Gigabit Ethernet LAN port (10/100/1000 Mbps)
I/O Ports
• RJ-45 port
• DC-in jack
• HDMI
• 2 x USB 2.0 port (Mouse, UPS, Flash Disk, HDD with external power)
• 3.5mm audio input x 1, output x 1
Power Adapter
• DC 12 V/3 A
OS
• Linux
Supported Cameras
• Supports all D-Link network cameras and megapixel resolution
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome, or Safari
Recording Performance
• First video profile:
• H.264 at 720p at 270 fps
• Secondary video profile:
• H.264 at VGA at 135 fps
Camera Search
• UPnP
Audio and Video Recording
• Synchronized audio & video recording
Compression Format
• H.264, MPEG-4, M-JPEG
Video Setting
• Resolution, quality, frame rate, enable audio, go to camera interface
Recording Type
• Record by schedule, manual, and event-based recording
• Motion-triggered recording
Remote Live View
• Supported via browser
• Supports mydlink portal
Remote Live View Control
• Live view, preset/go, patrol, focus, PTZ functions, snapshot, full screen, digital zoom
• e-map
Remote Playback Control
• Playback with normal, fast forward/rewind and step forward/rewind
Remote Playback
• Supported via browser and NVR client
• Playback system with timeline GUI, search by event, area, cameras, date, and time
• Browser or NVR Remote Client support four channel simultaneous playback
• Digital zoom
Overwrite Recording
• Auto recycling when disk storage is full
File Export
• Local : Export videos to AVI
• Remote: Export videos to AVI or ASF file
• Export images to BMP or JPG file
User Account
• Additional accounts can be created to allow users system access and specify authorization for camera channels, PTZ
DDNS
• D-Link DDNS and DynDns server support
System Time
• Set the system time (D-Link NTP, input time, sync with computer, Daylight Saving Time)
Remote Backup
• Remote backup software can backup raw data to redundant storage
System Status
• Camera status
• System status
Network Service Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• NTP Client
• DNS Client
• DDNS Client
• SMTP  Client
• FTP Client
• HTTP Server
• IP filtering
• UPnP
• HTTPS
• Bonjour
• SNMP
User Interface
• HTTP Web browser
• mydlink portal
• Smart phone
• NVR Search utility
Package Contents
• mydlink One-bay standalone NVR
• Power Adapter
• Ethernet Cable
• Quick Installation Guide
• CD-ROM with:
  Software
  Product Documentation
Fiziskie raksturlielumi
Weight
• 0.425 kg
Maximum Power Consumption
• 30 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• 5% to 90% non-condensing
Certifications
• CE
• FCC
• RoHS
• BSMI
Dimensions
* Hard disk is not included. Please, view the list of DNR-312L-compatible hard disks.
Sertifikāti
Informācija pasūtījumam
Attēli
DNR-312L
Вид сзади
Skatiet arī
