Ātrā meklēšana
Produkta iespējas:
HD Wireless Outdoor Network Camera
EOL
Īpašības:
Features
Camera Hardware Profile
• 1/4” Megapixel progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination: 0 lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) Filter module
• Built-in PIR sensor (5 meter)
• Built-in microphone
• 10x digital zoom
• Focal length: 3.45 mm
• Aperture: F2.0
• Exposure time: 1/7.5 to 1/10,000 sec.
• Minimum object distance: 500 mm
• Angle of view:
  (H) 57.8°
  (V) 37.8°
  (D) 66°
Camera Housing
• IP65 compliant weatherproof housing
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280x720, 800x448,640x360, 480x272, 320x176 up to 30 fps recording*
• 4:3 - 960x720, 800x592, 640x480, 480x352, 320x240 up to 30 fps recording*
Audio Support
• AAC
• G.711
External Device Interfaces
• 10/100 BASE-TX Fast Ethernet port
• 802.11n/g/b wireless
• MicroSD/SDHC card slot
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• IGMP
• ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
Mobile Support
• Windows 8/7/Vista/XP, Pocket PC, tablet, or mobile phone
• mydlink mobile app for iOS and Android mobile devices
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
• Supports all management functions in web interface
• Remote management/control of up to 32 cameras
Fiziskie raksturlielumi
Weight
• 134 g ± 5%
Power Adapter
• Output: 5 V DC, 1.2 A
• Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
• 5 watts max.
Temperature
• Operating: -25° to 45°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• FCC class B
• C-Tick
• IC
* Frame rates when streaming video may vary depending on network conditions and method used.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
