Ātrā meklēšana
Produkta iespējas:
12X Speed Dome Network Camera
Īpašības:
Camera Hardware Profile
• Sony Super HAD-II 1/4" CCD sensor
• 650 TVL resolution
• Minimum illumination: 0.1 lux (Color), 0.01 lux (B/W)
• Built-in Infrared-Cut Removable (ICR) filter module
• Electronic shutter: 1 to 1/10000 second
• S/N ratio > 50 dB (AGC off)
• 12x optical zoom
• Fixed length: 3.8 to 45.6 mm
• Aperture: F1.6 to F2.7
• Angle of view:
  (H) 4.49° to 52.8°
  (V) 3.40° to 39.7°
  (D) 55.4° to 65.4°
PTZ Hardware Profile
• Pan travel: 360° endless
• Tilt travel: 10° to 170°
• Manual speed: 1° to 80°/second
• Presets: 256 points
• Preset Accuracy: 0.225°
• Preset Speed: 10° to 400°/second
• Sequence Paths: 8
• Auto Pan Paths: 4
• Cruise Paths: 8
• Pan and tilt speed proportional to zoom ratio
• Resume after power loss
• Home Functions: Preset, Sequence, Auto Pan, Cruise
• Auto Flip: Mechanical/Digital/Off
• Digital Slow Shutter
• Image Freeze
• Image Inverse
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 16 configurable privacy mask zones
• Configurable white balance, shutter speed, brightness, saturation,
contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• JPEG for still images
Video Resolution
• NTSC: 720 x 480, 352 x 240, 176 x 120 at up to 30 fps
• PAL: 720 x 576, 352 x 288, 176 x 144 at up to 25 fps
Audio Support
• G.726
External Device Interfaces
• 10/100 BASE-TX Ethernet port
• 8 alarm inputs
• 1 alarm output
• Audio input/output
• Video output
Network Protocols
• IPv4, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP / RTSP/ RTCP, IP filtering, 3GPP, IGMP, ONVIF Compliant
Security
• Administrator and user group protection
• Password authentication
System Requirements for Web Interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Event notification and upload snapshots/video clips via HTTP, SMTP, or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
Mobile Support
• Windows 7/Vista/XP system, Pocket PC, or mobile phone with 3GPP playback support
D-ViewCam™ System Requirements
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion triggered, or manual recording options
Fiziskie raksturlielumi
Power Input
• DC 12 V/2 A
Max. Power Consumption
• 14 W
Operating Temperature
• 0° to 40°C
Storage Temperature
• -20° to 70°C
Humidity
• 20% to 80% non-condensing
Weight
• 1.2 kg
Certifications
• CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
Dimensions
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
