DCS-3112EOL EOS
HD Day & Night Network Camera
Apraksts
High Resolution Surveillance
The D-Link DCS-3112 is a high-end HD Day & Night Network Camera, equipped with a 1/4” Megapixel Progressive Scan CMOS sensor and a 3.5-8 mm DC auto iris lens. The camera can capture HD video at resolutions of up to 1280 x 720/1280 x 1024 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard storage through the built-in SD Card slot.
Multiple Video Streams
The DCS-3112 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which require high image detail. H.264 and MPEG-4 produce a small file size, useful for extended recording or for use in low-bandwidth networks. Additionally, the DCS-3112 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3112 incorporates Power over Ethernet (PoE), which allows it to be easily installed in a variety of locations, even when no power outlet is nearby. The DCS-3112 also includes input and output ports that allow connectivity to external devices such as IR sensors, switches, and alarm relays. An RS-485 interface provides connectivity to an optional pan/tilt enclosure which effectively adds pan/tilt functionality to the DCS-3112. An additional 12 V interface provides power for an optional LED illuminator.
Smart And Easy To Use
The included D-ViewCam software allows you to view up to 32 cameras on a single computer screen from a central location. E-mail notifications can be sent whenever an event occurs, such as when motion is detected, if a camera is moved, or if a link to a camera is lost. Record snapshots and video automatically through motion-triggered recording, or according to a set schedule that you define.
Īpašības
Camera Hardware Profile
• Sony Exmor 1/4” 1.3 Megapixel progressive CMOS sensor
• Minimum illumination: 0.4 lux (Color); 0.04 lux (B/W)
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10X digital zoom
• DC iris varifocal length: 3.5 mm to 8 mm
• Aperture: F1.4
• Angle of view:
(H) 35.4° to 77.6°
(V) 26.6° to 57.6°
(D) 44.3° to 97.9°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 3 configurable privacy mask zones
• Configurable white balance, shutter speed, brightness, saturation, contrast, and sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144
• 4:3 - 1280 x 1024, 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144
• All resolutions support frame rates of up to 30 fps
Audio Support
G.726
External Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE
• 2 DI / 1 DO interface
• 12 V DC, 200 mA Output
• RS-485
• SD card slot
• Audio input / output
• Video output
Network Protocols
IPv4, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP/HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP/RTSP/RTCP, IP filtering, 3GPP, IGMP, ONVIF compliant
Security
• Administrator and user group protection
• Password authentication
System Requirements for Web Interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Event notification and upload of snapshots/video clips via HTTP, SMTP, or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
• Mobile Support Windows 7/Vista/XP system, Pocket PC, or mobile phone with 3GPP playback support
D-ViewCam™ System Requirements
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion-triggered or manual recording options
Sertifikāti
Informācija pasūtījumam
DCS-3112 HD Day & Night Network Camera
