DPN-100EOL EOS
GPON SFP ONT module
Apraksts
DPN-100 is a GPON stick which is completely compliant to SFP MSA structure, providing customers a great convenience to update the uplink port of their devices from the legacy Ethernet to up-to-date high bandwidth GPON.
The GPON stick integrates one GPON MAC & one Ethernet MAC inside, requires no external GPON ONU for the update.
Īpašības
Standard
• ITU-T G.984.x (supports G.984.5)
• SFP MSA, INF-8074i
• SFF-8472
• FCC 47 CFR Part 15, Class B
• FDA 21 CFR 1040.10 & 1040.11, Class I
• IEEE 802.3
• ITU-T G.984.2 Amd1, Class B+
Optical transmitter characteristics
Wavelength
• Min.: 1290 nm
• Typical: 1310 nm
• Max. 1330 nm
Side mode suppression ratio (SMSR)
• Min.: 30 dB
Optical spectrum width
• Max.: 1 nm
Average output optical power
• Min.: 0.5 dBm
• Max.: 5 dBm
Power-off optical power
• Max.: -45 DBm
Extinction ratio
• Min.: 10 dB
Optical receiver characteristics
Wavelength
• Min.: 1480 nm
• Typical: 1490 nm
• Max.: 1550
Sensitivity
• Max.: -28 DBm
Saturation optical power
• Min.: -8 DBm
Signal-detected assert level
• Max.: -29 DBm
Signal-detected deassert level
• Min.: -40 DBm
SGMII characteristics
Transmit rise time 20~80%
• Min.: 100 ps
• Max.: 200 ps
Transmit fall time 20~80%
• Min.: 100 ps
• Max.: 200 ps
Transmit output differential voltage
• Min.: 150 mV
• Max.: 400 mV
Transmit differential impedance
• Min.: 80 ohms
• Max.: 120 ohms
Receive data rate
• 1250 Mbps
Receive input differential voltage
• Min.: 50 mV
• Max.: 500 mV
Receive differential impedance
• Min.: 80 ohms
• Max.: 120 ohms
Physical Parameters
Max. power supply voltage
• Min.: -0.5 V
• Max.: 3.6 V
Operating power voltage
• Min.: 3.15 V
• Typical: 3.3 V
• Max.: 3.45 V
Supply current
• Typical: 620 mA
• Max.: 750 mA
Temperature
• Operating: -30° to 60°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% (non-condensing)
Sertifikāti
Informācija pasūtījumam
DPN-100 GPON SFP ONT module
