Ātrā meklēšana
Produkta iespējas:
Power over Ethernet (PoE) Adapter Kit
EOL EOS
Īpašības:
Category 5 (CATS) Ethernet Pin Usage
Data: 1,2,3,6
Power: 4,5,7,8
LEDs
Power (Base Unit)
Power (Terminal Unit)
Voltage (Power Supply)
Input: 100-240V AC, 50/60Hz
Output: 48V DC, 400mA
Voltage (Base & Terminal Unit)
Base Unit Input: 48V DC, 400mA
Terminal Unit Output: 5V DC, 2.5A or 12V DC, 1A
Temperature
Operating: 32-104°F (0-40°C)
Storing: -40-158°F (-40-70°C)
Humidity
Operating: 10%-80% RH
Storing: 5%~90% RH
Certifications
FCC Class B
CE
C-Tick
Dimensions
L = 52.0mm
W = 80.9mm
H = 28.0mm
Weight
.256lbs
Warranty
1 Year
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
