Ātrā meklēšana
Produkta iespējas:
ShareCenter Shadow Network Storage with 4 Drive Bays, 10/100/1000Base-T Port and USB Port
EOL EOS
Īpašības:
Standards
• IEEE 802.3
• IEEE 802.3ab
• IEEE 802.3u
• TCP/IP
• CIFS/SMB
• NFS
• AFP
• DHCP Client
• DDNS
• NTP
• FTP over SSL/TLS, FXP
• HTTP/HTTPS
• LLTD
• PnP -X
• UPnP AV
• USB 2.0
• Bonjour
• WebDAV
LEDs
• Power
• LAN
• HDD 1
• HDD 2
Ports
• 10/100/1000 Gigabit Ethernet Port
• 1 USB 2.0 Port
• Power
Supported Hard Drive Type*
• 3.5” Internal, SATA I/II – Up to 2 TB capacity***
Disk Management
• Multiple Hard Drive Configurations: RAID 0, RAID 1, JBOD, Standard
• RAID migration from Non-RAID to RAID 1
• Hard Drive Format: EXT3
• Scandisk
• S.M.A.R.T.
Download Management
• HTTP/FTP schedule download
• Peer to peer (P2P)
Account Management
• User account management
• Group account management
• User/Group Quota management
• Network Share management
• ISO Mount management
Backup Management
• Schedule Backup from PC to NAS
• Schedule Local Backups
• Schedule Remote Backups
• Apple Time Machine support
• USB Backups
Remote File Sharing
• Remote File Access (AjaXplorer, WebDAV)
Device Management
• Internet Explorer 7+, Mozilla Firefox 3+ or Apple Safari 4+
• Easy Search Utility
• E-Mail Notifications
• SMS Notifications
• System/FTP log
• Yahoo! Widget
File Sharing
• Max. User Account: 256 users
• Max. Group: 32 groups
• Max. Shared Folder: 128 folders (without BT)
• Max. Con-current Connection: 64 connections (Samba)/10 connections (FTP)
Default Applications
• FTP/HTTP Downloads
• Remote Backups
• Local Backups
• P2P Downloads
• Web File Server
Add-on Applications
• SqueezeCenter
• Blog
• Audio Streamer
• AjaXplorer
• Photo Center
Power Management
• Power Saving mode
• Auto Power Recovery
• Schedule Power off
• Smart Fan control
• D-Link Green Ethernet
Power Supply
• External Power Supply
• DC 12 V/4 A Switching
Power Consumption
• Normal mode: 21.04 W
• Sleep mode: 10.45 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Operating Humidity
• 5% to 90% (non-condensing)
Dimensions
• 104 x 198 x 132 mm
weight
• 1.225 kg
Multilingual Support
• Samba: Unicode
• FtP Client/iTunes Server: Unicode , Croatian, Cyrillic (Kyrgyz Republic), Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Norwegian, Polish, Portuguese, Romanian, Russian, Simplified Chinese, Slovenian, Spanish, Swedish, Traditional Chinese, Turkish, Korean, Hebrew
* SATA drives are not included with the ShareCenter Shadow and must be purchased separately. RAID 1 mirroring requires the use of two internal SATA drives. To avoid data incompatibility in RAID 1 operation, use SATA drives from the same manufacturer. Formatted drive capacity for RAID 1 operation is dependant on the drive capacity of the lowest-sized drive. May not work with older generation SATA drives. For a list of SATA drives that have been tested to work with the ShareCenter Shadow, visit D-Link support websites.
** D-Link cannot guarantee full compatibility or proper playback with all codecs. Playback capability depends on the codec support of the UPnP AV media player.
*** Maximum HDD capacity supported may increase in future depending on advances in SATA technology.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
