KVM-450EOL
16-Port KVM Switch with VGA and USB Ports
Apraksts
The D-Link KVM-450 16-port KVM switch with VGA and USB ports allows you to manage up to sixteen computers with one monitor, one keyboard and one mouse. The KVM-450 requires no driver installation and can function without external power adapter connection by powering from USB port of your PC (the included power adapter can be used when connecting external device, for example, USB-disk, to the USB port of the KVM-450). This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The KVM-450 allows you to switch between computers quickly and easily using the buttons located on the front panel or IR remote controller. The KVM-450 supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires. This KVM switch can be mounted in a 19-inch rack with the included mounting brackets.
Īpašības
Hardware
Ports for connecting KVM cables
• 16 VGA ports
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): USB Type-A
• Mouse (local): USB Type-A
Port for connecting external devices
• USB Type
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (VGA)
• Keyboard/Mouse: USB Type-A connector
LEDs
• 16 port LEDs for connected PCs
Buttons
• 16 port switching buttons
• Reset button
Enclosure
• Metal, 19-inch rack mountable
General Specifications
Connected PCs
• Up to 16
Autoscan mode
• Yes
Switching between PCs
• Switching buttons on the front panel
• IR remote controller
Sound notification of switching
• Yes
Max. resolution
• 1920x1440
Physical Parameters
Weight
• 2.91 kg
Dimensions (L x W x H)
• 490 x 180 x 50 mm
Environmental Conditions
Power Supply
• From USB port on PC
• Power adapter when using external devices
Temperature
• Operating: -50 to 80 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
Compatible KVM cables*
• DKVM-CU/B
• DKVM-CU3/B
• DKVM-CU5/B
* NOTE! The KVM cables of hardware revision B are compatible only with the KVM-450 KVM switch of hardware revision C.
Sertifikāti
Informācija pasūtījumam
KVM-450 16-Port KVM Switch with VGA and USB Ports
