KVM-221
2-Port KVM Switch with VGA and USB Ports
Kur iegādāties
Apraksts
The D-Link KVM-221 2-port KVM switch with VGA and USB ports allows you to manage two computers with one monitor, one keyboard and one mouse. The KVM-221 requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The KVM-221 allows you to switch between computers quickly and easily using the buttons located on the top panel, keyboard hot keys or smart desktop controller. The KVM-221 supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires. This device is equipped with two built-in KVM cables of 1.4 m length with VGA and USB connectors.
Īpašības
Hardware
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): USB Type-A
• Mouse (local): USB Type-A
Port for connecting smart desktop controller
• Jack 3.5-F mm
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (VGA)
• Keyboard/Mouse: USB Type-A connector
LEDs
• 2 port LEDs for connected PCs
Buttons
• Switching button
Enclosure
• Metal
General Specifications
Connected PCs
• 2
Autoscan mode
• Yes
Switching between PCs
• Switching button on the top panel
• Hot keys
• Smart desktop controller
Sound notification of switching
• Yes
Max. resolution
• 2048x1536
Physical Parameters
Weight
• 490 g
Dimensions (L x W x H)
• 78 x 64 x 23 mm
Environmental Conditions
Power Supply
• From USB port on PC (no external power adapter required)
Temperature
• Operating: 0 to 50 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
KVM-221  2-Port KVM Switch with VGA and USB Ports
Attēli
KVM-221/Cx
Вид справа
Вид сверху
Skatiet arī
