DEM-311GT
1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
Kur iegādāties
Apraksts
The DEM-311GT/DD Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. This transceiver provides the Gigabit operation and physical compactness to deliver the speed, reliable long-distance (up to 550 m) data transfer, and deployment fexibility that today’s fiber networks require.
The DEM-311GT/DD transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards and is interoperable with D-Link Gigabit switches. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
Īpašības
Standard
• IEEE 802.3z 1000Base-SX
Wavelength
• 850 nm
Data Rate
• 1.25 Gbps
Connector
• Duplex LC
Fiber Type
• 50/125 um Multi-mode Fiber
Maximum Fiber Cable Length
• 550 m
Transmit Power Range
• -3 to -10 dBm
Receive Power Range
• -3 to -20 dBm
Sensitivity
• -20 dBm
Physical Parameters
Power Support
• 3.3 V
Supply Current
• 300 mA
Temperature
• Operating: 0° to 70°C
• Storage: -40° to 85°C
Humidity
• Operating: 0% to 85%
• Storage: 0% to 85%
Dimensions
• 55.4 mm x 13.7 mm x 8.5 mm
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DEM-311GT/DD/J1  1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
Attēli
DEM-311GT/J1
Вид сверху
Вид снизу
Skatiet arī
