Ātrā meklēšana
Produkta iespējas:
8 Ports 10 / 100 Mbps PoE + 8 Ports 10 / 100 Mbps + 2 10 / 100 / 1000BASE-T / SFP Combo Ports Unmanaged Switch
Īpašības:
Device Interfaces
• 16 10 / 100 Mbps PoE ports
• 2 10 / 100 / 1000BASE-T / SFP combo ports
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3z
• IEEE 802.3x Flow Control
Switching Fabric
•  7.2 Gbps
64 Byte Max. Forwarding Rate
• 5.36 Mpps
Transmission Method
•  Store-and-forward
MAC Address Table
• 8k
Packet Buffer
• 384 KB
Media Interface Exchange
•  Auto MDI/MDIX adjustment for all ports
LED Indicators
• Per unit: Power
• Per port: Activity / Link and Speed
• Per PoE port: Power fail, Power OK
Fan
• 1 Smart fan
PoE Standard
• IEEE 802.3af
PoE Ports
• Ports 1~16 up to 15.4 W per port
PoE Power Budget
• 246.4 watts
Surge Protection
• Ports 1~16 up to 2 kV
Physical
Dimensions
• 11” x 8.3” x 1.7” (280 mm x 210 mm x 44 mm)
Weight
• 2.15 kg (4.74 lbs)
Power
• Internal AC input: 100 ~ 240 VAC, 50~60 Hz
Power Consumption
• Maximum Power Consumption: 102.6 watts (PoE on), 14.3 watts (PoE off)
• Standby Power Consumption: 7.1 W / 100 V , 8.3 W / 240 V
Temperature
• Operating: 0 to 40 ˚C (32 to 104 ˚F)
• Storage: -40 to 70 ˚C (-40 to 158 ˚F)
Humidity
• Operating: 0% to 95% RH non-condensing
• Storage: 0% to 95% RH non-condensing
MTBF
• 361,802 hours
Heat Dissipation
• 1029.5 BTU/h
Certifications
• FCC Class A
• CE
• CCC
• RoHS
• VCCI
• BSMI
• C-Tick
Safety
• CB
• cUL
• LVD
• CCC
• BSMI
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
