DGS-6600-CMProjektiem
Control module
Kur iegādāties
Apraksts
Control module for DGS-6600
Īpašības
- 480G Switching capacity
- 1 female DCE RS-232 DB-9 and 1 female USB Series type B console port
- 1 10/100/1000Mbps RJ45 out-of-band management port support out-of-band SNMP, Web, telnet management
- 2 CF card slots for portable images and configurations files
- CPU: 1.3GHz
- RAM: 2GB
- Flash memory: Prom 4MB, Runtime 1GB (internal CF card)
Fiziskie raksturlielumi
Power consumption
Max 53.856W
Heat dissipation
183.6BTU/hr
MTBF (hours)
263.581
Operating temperature
0 to 50°C
Storage temperature
-40 to 70°C
Operating humidity
10% to 90% non-condensing
Storage humidity
5% to 90% non-condensing
Sertifikāti
Informācija pasūtījumam
DGS-6600-CM Control module for DGS-6600
Attēli
DGS-6600-CM
Skatiet arī
