DIR-825EOL EOS
AC1200 Wave 2 MU-MIMO Wi-Fi Gigabit Router with 3G/LTE Support and USB Port
Aprašymas
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer.1
Wireless Interface
Using the DIR-825 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps2).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA3), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-825 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the router supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-825 via the user-friendly web-based interface (the interface is available in several languages).
The configuration wizard allows you to quickly switch DIR-825 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-825 supports configuration and management via mobile application for Android and iPhone smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1When using a USB hub with external power supply. Simultaneous operation of two USB modems is not supported.
2Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
Bendros charakteristikos
				 Hardware
				 Processor
				 • RTL8197FS (1GHz)
				 RAM
				 • 128MB, DDR2, built in processor
				 Flash
				 • 32MB, SPI
				 Interfaces
				 • 10/100/1000BASE-T WAN port
				• 4 10/100/1000BASE-T LAN ports
				• USB 2.0 port
				 LEDs
				 • Power
				• Internet
				• 4 LAN LEDs
				• WLAN 2.4G
				• WLAN 5G
				• WPS
				• USB
				 Buttons
				 • POWER button to power on/power off
				• WIFI button to enable/disable wireless network
				• WPS button to set up wireless connection
				• RESET button to restore factory default settings
				 Antenna
				 • Four external non-detachable antennas (5dBi gain)
				 MIMO
				 • 2 x 2, MU-MIMO
				 Power connector
				 • Power input connector (DC)
				 Software
				 WAN connection types
				 • LTE
				• 3G
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • Support of IEEE 802.1X for Internet connection
				• DHCP server/relay
				• Advanced configuration of built-in DHCP server
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				• DNS relay
				• Dynamic DNS
				• Static IPv4/IPv6 routing
				• IGMP/MLD Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN failover
				• Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
				• Setup of maximum TX rate for each port of the router
				• Built-in UDPXY application
				• XUPNPD plug-in
				• Segmentation of traffic between LAN ports
				 Firewall functions
				• IPv4/IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				• IPsec tunnels
				   - IKEv1 support
				   - DES encryption
				   - NAT Traversal
				   - Support of DPD (Keep-alive for VPN tunnels)
				 USB interface functions
				 • USB modem
				   - Auto connection to available type of supported network (4G/3G/2G)
				   - Auto configuration of connection upon plugging in USB modem
				   - Enabling/disabling PIN code check, changing PIN code1
				• USB storage
				   - File browser
				   - Print server
				   - Access to storage via accounts
				   - Built-in Samba/FTP/DLNA server
				   - Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management and monitoring
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Multilingual web-based interface for configuration and management
				• Support of D-Link Assistant application for Android and iPhone smartphones
				• Support of logging to remote host/connected USB storage
				• Ping utility
				• Traceroute utility
				• TR-069 client
				• Automatic reboot on schedule
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11ac Wave 2
				• IEEE 802.11a/b/g/n
				 • Frequency range
				The frequency range depends upon the radio frequency regulations applied in your country
				 • 2400 ~ 2483.5MHz
				• 5150 ~ 5350MHz
				• 5650 ~ 5850MHz
				 Wireless connection security
				 • WEP
				• WPA3 (Personal)
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Rate limitation for wireless network/separate MAC addresses
				• Periodic scan of channels, automatic switch to least loaded channel
				• Support of 802.11ac (5GHz) and 802.11n (2.4GHz) TX Beamforming
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				• Support of STBC
				 Wireless connection rate
				 • IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n (2.4GHz): from 6.5 to 300Mbps (MCS0–MCS15)
				• IEEE 802.11n (5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
				• IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MCS9)
				 Transmitter output power
				 • 802.11a (typical at room temperature 25 °C)
				14dBm at 6, 9, 12, 18, 24Mbps
				13dBm at 36Mbps
				12.5dBm at 48Mbps
				12dBm at 54Mbps
				• 802.11b (typical at room temperature 25 °C)
				15dBm at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
				• 802.11n (typical at room temperature 25 °C)
				2.4GHz, HT20
				15dBm at MCS0~7
				2.4GHz, HT40
				15dBm at MCS0~7
				5GHz, HT20
				14dBm at MCS0~4
				13dBm at MCS5
				12.5dBm at MCS6
				12dBm at MCS7
				5GHz, HT40
				14dBm at MCS0~2
				13dBm at MCS3~4
				12.5dBm at MCS5~6
				12dBm at MCS7
				• 802.11ac (typical at room temperature 25 °C)
				VHT20
				14dBm at MCS0~4
				13dBm at MCS5
				12dBm at MCS6
				11dBm at MCS7/8
				VHT40
				14dBm at MCS0~2
				13dBm at MCS3~4
				12dBm at MCS5~6
				11dBm at MCS7/8/9
				VHT80
				14dBm at MCS0~4
				13dBm at MCS5~6
				12dBm at MCS7
				11dBm at MCS8/9
				 Receiver sensitivity
				 • 802.11a (typical at PER < 10% (1000-byte PDUs) at room temperature 25 °C)
				-82dBm at 6Mbps
				-81dBm at 9Mbps
				-79dBm at 12Mbps
				-77dBm at 18Mbps
				-74dBm at 24Mbps
				-70dBm at 36Mbps
				-66dBm at 48Mbps
				-65dBm at 54Mbps
				• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
				-80dBm at 1Mbps
				-80dBm at 2Mbps
				-76dBm at 5.5Mbps
				-76dBm at 11Mbps
				• 802.11g (typical at PER < 10% (1000-byte PDUs) at room temperature 25 °C)
				-82dBm at 6Mbps
				-81dBm at 9Mbps
				-79dBm at 12Mbps
				-77dBm at 18Mbps
				-74dBm at 24Mbps
				-70dBm at 36Mbps
				-66dBm at 48Mbps
				-65dBm at 54Mbps
				• 802.11n (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
				2.4GHz, HT20
				-82dBm at MCS0
				-79dBm at MCS1
				-77dBm at MCS2
				-74dBm at MCS3
				-70dBm at MCS4
				-66dBm at MCS5
				-65dBm at MCS6
				-64dBm at MCS7
				2.4GHz, HT40
				-79dBm at MCS0
				-76dBm at MCS1
				-74dBm at MCS2
				-71dBm at MCS3
				-67dBm at MCS4
				-63dBm at MCS5
				-62dBm at MCS6
				-61dBm at MCS7
				5GHz, HT20
				-82dBm at MCS0
				-79dBm at MCS1
				-77dBm at MCS2
				-74dBm at MCS3
				-70dBm at MCS4
				-66dBm at MCS5
				-65dBm at MCS6
				-64dBm at MCS7
				5GHz, HT40
				-79dBm at MCS0
				-76dBm at MCS1
				-74dBm at MCS2
				-71dBm at MCS3
				-67dBm at MCS4
				-63dBm at MCS5
				-62dBm at MCS6
				-61dBm at MCS7
				• 802.11ac (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
				VHT20
				-82dBm at MCS0
				-79dBm at MCS1
				-77dBm at MCS2
				-74dBm at MCS3
				-70dBm at MCS4
				-66dBm at MCS5
				-65dBm at MCS6
				-64dBm at MCS7
				-56dBm at MCS8
				VHT40
				-79dBm at MCS0
				-76dBm at MCS1
				-74dBm at MCS2
				-71dBm at MCS3
				-67dBm at MCS4
				-63dBm at MCS5
				-62dBm at MCS6
				-61dBm at MCS7
				-56dBm at MCS8
				-54dBm at MCS9
				VHT80
				-76dBm at MCS0
				-73dBm at MCS1
				-71dBm at MCS2
				-68dBm at MCS3
				-64dBm at MCS4
				-60dBm at MCS5
				-59dBm at MCS6
				-58dBm at MCS7
				-53dBm at MCS8
				-51dBm at MCS9
				 Modulation schemes
				 • 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11ac: BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 205 x 136 x 44 mm (8.07 x 5.35 x 1.73 in)
				 Weight
				 • 295 g (0.65 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 1A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DIR-825
				• Power adapter DC 12V/1A
				• Ethernet cable
				• Quick Installation Guide” (brochure)
				 Supported USB modems1
				 • GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Alcatel IK40V
				• D-Link DWM-222
				• Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372s/E3372h-153
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF827
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikatai
Informacija užsakymui
DIR-825/RU/R2A  AC1200 Wave 2 MU-MIMO Wi-Fi Gigabit Router with 3G/LTE Support and USB Port
