DUB-2325Naujiena
Hub with two USB 3.0 ports, USB Type-C port, SD and microSD card slots and USB Type-C connector
Kur įsigyti
Aprašymas
The D-Link DUB-2325 Hub with USB Type-C connector provides an easy way to connect up to three USB devices to your notebook or desktop computer and allows you to insert SD and microSD cards into the corresponding slots.
Add Three USB Ports to Your Computer
With the DUB-2325 Hub, you can conveniently add two USB 3.0 ports and one USB Type-C port to connect up to three USB peripheral devices to your PC. USB 3.0 technology supports data rates of up to 5 Gbps, which means that you can enjoy faster transfer speeds compared to previous USB standards.
Dual Slot SD Card Reader
The DUB-2325 Hub is equipped with the SD and microSD card slots. Use the dual slot card reader to access data on a SD and microSD card simultaneously.
Plug-and-play support
Simply connect the DUB-2325 to any PC (you can also plug in the power adapter if it is necessary). It’s that easy - no drivers or software installation is required.
Bendros charakteristikos
Interfaces
• Two USB 3.0 Type-A ports
• One USB Type-C port (for data transmission only)
• SD card slot
• microSD card slot
• One USB Type-C connector
LEDs
• Power LED
Standards
• USB 3.0 for Type-C
• USB 3.0
• USB 2.0
• USB 1.1
• OHCI
• UHCI
• EHCI
• xHCI
Data rate
• Up to 5 Gbps
Connectivity rules
• Up to 127 devices
• Hub cascading
System requirements
• Available USB Type-C port
• Windows XP/Vista/7/8/10, Mac OS, Linux
Physical Parameters
Dimensions (L x W x H)
• 108 x 35 x 13.5 mm
Power input
• From PC (USB bus powered)
• 5 V / 2 A DC power adapter (Micro-USB)
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 70  °C
Humidity
• Storage: 5% to 90% non-condensing
Fiziniai parametrai
Sertifikatai
Informacija užsakymui
DUB-2325   Hub with two USB 3.0 ports, USB Type-C port, SD and microSD card slots and USB Type-C connector
Paveikslas
DUB-2325
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš priekio
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
