DGS-1008MP
8-Port PoE Desktop Switch
Kur įsigyti
Aprašymas
The D-Link DGS-1008MP 8-Port Desktop Switch with 8 PoE Ports is an ideal solution for small office or enterprise environments looking to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless Access Points (APs), IP cameras, and IP phones. Built with small business and enterprise users in mind, the DGS-1008MP is a high-speed, flexible switch that features a fanless, quiet design so it can be conveniently placed anywhere in a working environment.
Power over Ethernet
The DGS-1008MP features eight 10/100/1000BASE-T ports that support the IEEE 802.3at Power over Ethernet (PoE) standard. Each of the eight PoE ports can supply up to 30 W, with a total combined PoE budget of 125 W, allowing users to power up to eight IEEE 802.3at-compliant devices without requiring an additional power supply. This allows devices to be installed in locations without their own power outlet, saving on installation costs and reducing the time it takes to install new devices.
Superior Performance
The DGS-1008MP is a plug-and-play device, meaning installation is quick and easy and requires no additional configuration. Support for Auto MDI/MDI-X on all ports eliminates the need for crossover cables when connecting to another switch or hub. Auto-Negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for optimal compatibility and performance. With store-and-forward switching, the DGS-1008MP also maximizes network performance while minimizing packet loss during data transmission. Combining the convenience of PoE, superior performance, and ease of use, the DGS-1008MP is the ideal choice for flexibly expanding your network while remaining cost-efficient.
Compact and Silent Design
The DGS-1008MP has a compact 11” design, so that it can be deployed in any easily accessible location on the work floor, allowing you to power a set of PoE-powered devices while avoiding additional cable clutter. Alternatively, the standardized 1U-sized housing means the switch can also be mounted in a standard 19” rack and be integrated in the server infrastructure. The DGS-1008MP is furthermore built around a fanless design. This makes the switch suitable to be used closer to, or in populated areas where it works efficiently while guaranteeing a quiet working environment.
Green Technology
The DGS-1008MP supports IEEE 802.3az Energy-Efficient Ethernet (EEE), reducing power consumption of the switch when network utilization is low and minimizing operating costs during periods of inactivity. By using EEE-compliant devices with the DGS-1008MP, organizations can noticeably reduce power consumption by having the switch automatically put ports into sleep mode when they are not being used.
Bendros charakteristikos
Size
• 11-inch desktop/rackmount size, 1U height
Device Interfaces
• 8 10/100/1000 Mbps ports
Port Standards & Functions
• IEEE 802.3i 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3at Power over Ethernet
• IEEE 802.3x Flow Control
• ANSI/IEEE 802.3 NWay auto-negotiation
Switching Capacity
• 16 Gbps switching fabric
Media Interface Exchange
• Auto MDI/MDIX
Transmission Method
• Store-and-forward
MAC Address Table
• 4K entries per device
Packet Buffer Memory
• 192 KB per device
Packet Filtering/Forwarding Rates
• Ethernet: 14 880 pps per port
• Fast Ethernet: 148 800 pps per port
• Gigabit Ethernet: 1 488 000 pps per port
Data Transfer Rates
• Ethernet:
  • 10 Mbps (half duplex)
  • 20 Mbps (full duplex)
• Fast Ethernet:
  • 100 Mbps (half duplex)
  • 200 Mbps (full duplex)
• Gigabit Ethernet:
  • 2000 Mbps (full duplex)
Network Cables
• 10BASE-T:
  UTP CAT 3/4/5/5e (100 m max.)
  EIA/TIA-586 100-ohm STP (100 m max.)
• 100BASE-TX:
  UTP CAT 5/5e (100 m max.)
 EIA/TIA-568 100-ohm STP (100 m max.)
• 1000BASE-T:
  UTP CAT 5/5e(100 m max.)
  EIA/TIA-568 100-ohm STP(100 m max.)
Physical Parameters
LED Indicators
• Per port: Activity / Link and Speed
• Per port: Power / Status
• Per device: PoE Max
Dimensions
• 280 x 180 x 44 mm
Weight
• 1.84 kg
Power Input
• AC Input: 100 to 240 V AC, 50/60 Hz
Maximum PoE Budget
• 125 watts
MTBF (hours)
• 182 920
Power Consumption
• 6.98 watts (PoE off)
• 140 watts (PoE on)
• PoE up to 30 watts per port
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 0% to 95% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
EMI
• CE Class A
• FCC Class A
• VCCI Class A
• CCC Class A
• BSMI Class A
Safety
• cUL
• CB
• LVD
• CCC
Fiziniai parametrai
Sertifikatai
Informacija užsakymui
DGS-1008MP  8-Port PoE Desktop Switch
Paveikslas
DGS-1008MP/B
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
