DXS-1210-16TCProjektams
Layer 2+ SmartPro Switch with 12 10GBase-T, 2 10GBaseX SFP+ Ports and 2 10GBase-T/SFP+ Combo Ports
Aprašymas
The D-Link DXS-1210-16TC 10 Gigabit Ethernet SmartPro Switch is a cost-effective 10 Gigabit switch capable of servicing a range of network needs in any business. Supporting 10GBase-T/SFP+ combo ports, this switch provides connection flexibility across a network allowing easier network integration. With high performance and low latency, the DXS-1210-16TC fulfills the needs for virtualization, cloud services, and server-to-server applications, making it perfect for Small-to-Medium-Business (SMB) customers.
Energy Efficient
By incorporating D-Link Green technology, this switch is capable of saving power without sacrificing operational performance or functionality. The switch features built-in smart fans with internal heat sensors that monitor and detect temperature changes and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower, reducing the switch’s power consumption and noise. Link status drastically reduces power consumption by automatically putting ports without a link into a sleep mode. The DXS-1210-16TC takes the approach to green IT one step further by incorporating a special chipset with advanced silicon technology for efficient use of energy.
Extensive Management and Layer 2 Features
The DXS-1210-16TC comes with a complete lineup of L2 features, includes port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down difficult to diagnose switching loops. The cable diagnostic feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing hassle-free diagnostics and maintenance.
Quality of Service and Bandwidth Control
The DXS-1210-16TC supports Auto Surveillance VLAN (ASV) and Auto Voice VLAN, which are best suited for VoIP and video surveillance deployments. Auto Surveillance VLAN is a new, industry-leading technology that consolidates data and surveillance video transmission through a single DXS-1210-16TC switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures quality real-time video monitoring and control without compromising the transmission of conventional network data. Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from IP phones to a designated VLAN. With higher priority and an individual VLAN, these features guarantee the quality and security of VoIP traffic. The Differentiated Service Code Point (DSCP) markings on Ethernet packets enable different levels of service to be assigned to network traffic. As a result, these voice and video packets take precedence over other packets. In addition, with bandwidth control, network administrators can reserve bandwidth for important functions that require higher priority or more bandwidth.
Secure your Network
D-Link’s innovative Safeguard EngineTM protects the switch against traffic flooding caused by malicious attacks. The DXS-1210-16TC supports 802.1X port-based and host-based authentication, allowing the network to be authenticated through external RADIUS servers. The Access Control List
(ACL) feature enhances network security and helps to protect the internal IT network. The DXS-1210-16TC also features Address Resolution Protocol (ARP) spoofing prevention, which protects from attacks on the network that may allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages. To prevent ARP spoofing attacks,
the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP server screening feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address.
Versatile Management
The DXS-1210-16TC comes with the D-Link Network Assistant (DNA) utility that simplifies the configuration of devices that support the D-Link Discovery Protocol. The D-Link Network Assistant utility easily allows customers to discover multiple D-Link Smart Switches within the
same L2 network segment and displays them on screen for instant access. With this utility, users do not need to change the IP address of their PC. This utility further allows for simultaneous configuration and basic setup of all discovered devices, including password changes and firmware upgrades. The DXS-1210-16TC also supports D-View 7 and a full Command Line Interface (CLI) through the console port and Telnet. D-View 7 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Seamless Integration
The DXS-1210-16TC comes with both RJ-45 and SFP+ ports capable of connecting to Cat. 6 and fiber for 10G Ethernet. The DXS-1210-16TC has 12 10GBase-T ports, 2 SFP+ ports, and 2 10GBase-T/SFP+ combo ports. This means the DXS-1210-16TC can provide a flexible solution for upstream or downstream server connections, making network administration easy.
Bendros charakteristikos
Interfaces
• 12 10GBase-T ports
• 2 SFP+ ports
• 2 10GBase-T/SFP+ combo ports
• RJ-45 console port
Port Standard & Functions
• IEEE 802.3u 100Base-TX Fast Ethernet
• IEEE 802.3ab 1000Base-T Gigabit Ethernet
• IEEE 802.3az compliance
• IEEE 802.3an 10GBase-T 10 Gigabit Ethernet
• IEEE 802.3ae 10GbE over fiber
• IEEE 802.3z 1000Base-X
• Auto MDI/MDIX support for 1000/10GBase-T
Diagnostic LEDs
• Power
• Fan Error
• Console
• Link/Activity/Speed (Per 10GBase-T port)
• Link/Activity/Speed (Per 10G SFP+ port)
Network Cables for 10GBase-T
• Cat. 6 (30 m max)
• Cat. 6A or Cat. 7 (100 m max)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all twisted-pair ports
Switching Capacity
• 320 Gbps
Maximum Packet Forwarding Rate
• 238.08 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• Up to 16K entries per device
Packet Buffer
• 2 Mbytes
Flash Memory
• 64 Mbytes
Software Features
L2 Features
• MAC Address Table: Up to 16K entries
• Static MAC Addresses: 1K
• IGMP Snooping:
  IGMP v1/v2 Snooping
  IGMP v3 awareness
  Supports 384 IGMP groups
  Supports at least 128 static multicast addresses
  Per VLAN IGMP Snooping
  Support host-based fast leave
• MLD Snooping:
  MLD v1 Snooping
  MLD v2 awareness
  Support 384 groups
  Support 128 static multicast addresses
• LLDP
• LLDP-MED
• Spanning Tree Protocol:
  802.1D STP
  802.1w RSTP
  802.1s MSTP
• Flow Control:
  802.3x Flow Control
  HOL Blocking Prevention
• Port Mirroring:
  One-to-One
  Many-to-One
  Supports Mirroring for Tx/Rx/Both
• 802.3ad Link Aggregation: Maximum of 8 groups/8 ports per group
• Jumbo Frame: Up to 9KB
• Loopback Detection
VLAN
• 802.1Q VLAN
• Port-based VLAN
• 4K VLAN Groups
• Configurable VID: 1~4094
• Voice VLAN
• Auto Surveillance VLAN
• GVRP*
• Asymmetric VLAN
Quality of Service (QoS)
• CoS based on:
  802.1p Priority Queues
  DSCP
  ToS
  IPv6 Traffic Class
  TCP/UDP port
  VLAN ID
  MAC Address
  Ether Type
  IP Address
  Protocol Type
  IPv6 Flow Label
• 802.1p Priority Queue
• 8 queues per port
• Queue Handling:
  Strict
  Weighted Round Robin (WRR)
  Deficit Round Robin (DRR)
  Weighted Deficit Round Robin (WDRR)
  Strict + WDRR
• Bandwidth Control:
  Port-based (Ingress/Egress, min. granularity 64 Kbps)
  iSCSI Awareness*
L3 Features
• IP Interface: Supports 8 IPv4/v6 interfaces
• ARP: 768 Static ARP
• Default Route
• Static Route:
  Max. 64 IPv4 entries
  Max. 64 IPv6 entries
Access Control List (ACL)
• Max. 50 access list
• Max. 256 ACL rules
• Max. 50 VLAN access map*
• ACL based on:
  802.1p priority
  VLAN*
  MAC address
  Ether type
  IP address
  DSCP
  Protocol type
  TCP/UDP port number
  IPv6 Traffic Class
  IPv6 flow label
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP-MAC-Port Binding:
  DHCP Snooping*
  IP Source Guard*
  Dynamic ARP Inspection*
  IPv6 Snooping*
  IPv6 Source Guard*
  DHCPv6 Guard*
  IPv6 ND Inspection*
  IPv6 Route Advertisement (RA) Guard*
• Traffic Segmentation
• SSH*:
  Support v1/ v2
  Support IPv4/ IPv6
• SSL:
  Support v1/v2/v3
  Support IPv4/IPv6
• ARP Spoofing Prevention*: Max. 127 entries
• DoS Attack Prevention
• Port Security: Supports up to 6656 MAC addresses per port
• Duplicate Address Detection
Operations, Administration, and Management (OAM)
• Cable Diagnostics
Authentication, Authorization, and Accounting (AAA)
• Web-based Access Control (WAC)*:
  Support local/RADIUS database
  Support Port-based access control
  Support Host-based access control
  Support Dynamic VLAN Assignment
  Identity-driven Policy (VLAN/ACL/QoS) Assignment
• 802.1X Authentication:
  Supports local/RADIUS database
  Supports Port-based access control
  Supports Host-based access control
  Supports EAP, OTP, TLS, TTLS, PEAP
• Support IPv4/IPv6 RADIUS Server
• Support IPv4/IPv6 TACACS+*
• Guest VLAN
• Compound Authentication*
• Authentication for management access
• Authentication Database Failover*
• MAC-based Access Control (MAC)*:
Management
• Web-based GUI
• D-Link Network Assistant Utility
• Full CLI
• Telnet Server
• TFTP Client
• Configurable MDI/MDIX
• SNMP: Supports v1/v2c/v3
• SNMP Trap
• Smart Wizard
• LLDP
• LLDP-MED
• DHCP Relay*
• System Log
• BootP/DHCP Client
• SNTP
• ICMP v6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration*
• RMON v1/v2*
• Trusted Host
• Dual Images
• Dual Configurations
• DNS Client*
• Debug command
Green V3.0 Technology
• Power Saving by:
  LED Shutoff
  System Hibernation
  Port Shutoff
MIB/RFC Standards
• RFC 783 TFTP
• RFC 951 BootP/DHCP Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP/DHCP Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2131 BootP/DHCP Client
• RFC 2138 RADIUS Authentication*
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC-2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2618 RADIUS Authentication*
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• D-Link Private MIB
• LLDP MIB
• Zone Defense MIB
• 2233 Interface Group MIB
Physical Parameters
Power Input
• 100 to 240 V AC
Maximum Power Consumption
• 90.81 W
Standby Power Consumption
• 43.65 W
Weight
• 3.15 kg
Dimensions
• 440 x 210 x 44 mm
Temperature
• Operating: -5° to 50°C
• Storage: -40° to 70°C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• CE
• FCC
• C-Ticket
• VCCI
• BSMI
• CCC
Safety
• cUL
• CB
• CE
• CCC
• BSMI
* This feature will be supported in a future firmware release.
Sertifikatai
Informacija užsakymui
DXS-1210-16TC  Layer 2+ SmartPro Switch with 12 10GBase-T, 2 10GBaseX SFP+ Ports and 2 10GBase-T/SFP+ Combo Ports
Paveikslas
DXS-1210-16TC/A3
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš galo
DXS-1210-16TC/A2
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
