DGS-1005D
5-Port 10/100/1000M Unmanaged Switch
Kur įsigyti
Aprašymas
The DGS-1005D 5-Port 10/100/1000M Unmanaged Switch is part of D-Link™s new series of SOHO devices that make use of D-Link™s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. It provides five Gigabit ports for easy expansion of your network and a quick way to upgrade your network to Gigabit connectivity. An energy-efficient power adapter (Energy Star Level VI qualified),
minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Fast and Smooth Networking
With data transfer speeds of up to 2000 Mbps on Gigabit Ethernet, the D-Link DGS-1005D 5-Port 10/100/1000M Unmanaged Switch is ideal all types of networking tasks. Support for 802.3x Flow Control means smoother network traffic, resulting in an overall boost in performance and reliability. Featuring QoS, the DGS-1005D prioritizes network traffic by type so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media, VoIP calls, and online gaming.
Conserve Energy
The 5-Port 10/100/1000M Unmanaged Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save a substantial amount of power by cutting power usage for unused ports or ports connected to computers that have been shut down.
Environmentally-friendly
The 5-Port 10/100/1000M Unmanaged Switch was designed with the environment in mind, and is compliant with Energy Star Level VI, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
Bendros charakteristikos
Device Interfaces
• Five 10/100/1000 Gigabit LAN ports
Advanced Features
• Green Ethernet
• 10 Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Secure store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Supports 9,720 bytes Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
Protocol
• CSMA/CD
Data Transfer Rates
• Ethernet:
  10 Mbps (half duplex)
  20 Mbps (full duplex)
• Fast Ethernet:
  100 Mbps (half duplex)
  200 Mbps (full duplex)
• Gigabit Ethernet:
  2000 Mbps (full duplex)
Transmission Method
• Store-and-forward
MAC Address Table
• 4 K
MAC Address Learning
• Automatic Update
Packet Filtering/Forwarding Rates
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
• Gigabit Ethernet: 1,488,000 pps per port
RAM Buffer
• 128 KB per device
LED Indicators
• Per port: Link/Activity/Speed
• Per device: Power
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
Dimensions
• 90 x 65 x 27 mm
Weight
• 140 grams
Power
• 5 V/1 A Power Adapter
Power Consumption
• Power On (Standby) AC input: 0.7 watts
• Maximum AC input: 3.9 watts
Temperature
• Operating: 0 to 40 °C
• Storage: -10 to 70 °C
Humidity
• Storage: 5% to 90% non-condensing
MTBF
• 1,152,117 hours
Certifications
• CE class B
• FCC class B
• ICES-003 Class B
• VCCI class B
• C-Tick
• cUL
• CB
• LVD
Fiziniai parametrai
Sertifikatai
Informacija užsakymui
Paveikslas
DGS-1005D/I
Vaizdas iš priekio
Vaizdas iš dešinės
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
