DIR-825/A/D1AEOL EOS
Wireless Dual-Band N600 Router with Gigabit Ethernet ports
Tanımlama
Wireless Interface
Using a wireless router DIR-825, you can quickly create a high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz wireless network allows for a wide range of tasks. The Router can serve as a base station for a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n (at speeds up to 600 Mb / s *).
In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Built-in antennas Airgain
The router is equipped with a built-in omni-directional antennas AirGain. Despite its compact size, these antennas are not only not inferior in performance to traditional pin, but in many ways superior to them. With a high gain (4 dBi for the 2.4 GHz, 6 dBi for 5 GHz) and the circular radiation pattern in the horizontal and vertical planes, antenna AirGain work equally well in either direction, provide enhanced wireless coverage and reduce the likelihood of "dead" zones.
USB-port
The router is equipped with a USB-port for connection of USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router, USB-drive, which will be used as a network drive, or a printer.
Safety
Wireless Router DIR-825 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network.
Configuration and Management
To manage and configure your wireless router DIR-825 uses a simple and user-friendly web-based interface (available in several languages).
* Up to 300 Mbit / s in the 2.4 GHz and up to 300 Mbit / s in the 5 GHz band
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DIR-825/A/D1A/D1
Back view
View from the right
Front view
İndir
Destek Merkezi
