DWA-566EOL EOS
Dual-band Wi-Fi 802.11n (2.4/5GGts) PCIe-adapter, up to 300 Mbit / s
Tanımlama
Using two frequency bands
Wireless PCIe-300 Wireless N Adapter D-Link supports dual-band, ensuring the transmission of Internet traffic in the 2.4 GHz and broadcast media on the 5GHz frequency. Using PCIe-Adapter D-Link Wireless 300 series provides simultaneous viewing of Web-pages, file downloads and streaming of HD video without delay.
The increased speed and extended the range of the network
Connect to high-speed wireless network using a PCIe-adapter, the D-Link Wireless N 300. Extended range and increased speed guarantee a fast and reliable connection anywhere in your home.
Benefits of PCI Express
PCI Express offers higher bandwidth and increased performance and allows you to connect an adapter DWA-566 PCIe slot to any computer - x1, x4, x8, or x16.
Easy to install and use
Setup wizard provides step by step instructions that you can use to quickly and easily connect to a wireless network, even in the absence of experience with networks. Also bundled is a utility for managing wireless connections (D-Link Wireless Manager), which enables you to save your most frequently used wireless networks.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DWA-566/A1
Front view
Left side view
İndir
Destek Merkezi
