DCS-7517/UPAEOL EOS
5 Megapixel Day & Night Outdoor Network Camera
Tanımlama
The D-Link DCS-7517/UPA 5 Megapixel Day & Night Outdoor Network Camera is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a 5 megapixel progressive scan CMOS sensor to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for additional accessories. Built for the Outdoors Specially built for outdoor use, the DCS-7517/UPA has an IP66 weatherproof housing that protects it from dirt and rain. Combined with its power over Ethernet (PoE) capability, the DCS-7517/UPA truly is a versatile solution that be used in a wide range of applications.
Continuous Monitoring
In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-7517/UPA also has built-in IR LED illuminators with a 30 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day.
To maximize bandwidth efficiency and improve image quality, the DCS-7517/UPA provides real-time video compression using the H.264, and MJPEG codecs, and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory.
Flexible Connectivity
The DCS-7517/UPA has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
Robust Management Software
The DCS-7517/UPA 5 Megapixel Day & Night Outdoor Network Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
Genel Özellikler
Camera Hardware Profile
• 1/3.2” 5 Megapixel CMOS sensor
• 30 meter IR illumination distance
• Built-in Infrared-Cut Removable (ICR) Filter module
• Minimum illumination:
• 0.5 lux Color mode
• 0.1 lux Black and White mode
• 0 lux Black and White mode with IR LED on
• Minimum object distance 0.3 m
• 2.8 ~ 12 mm motorized zoom vari-focal DC iris lens
• Aperture F1.8
• Angle of view
• (H) 25.49° to 85.02°
• (V) 17.09° to 65.47°
• Shutter Speed: 1/2.5 ~ 1/10,000
• 4x digital zoom
Camera Housing
• IP66 compliant weatherproof housing
• Included sunshield
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• Tamper detection
• Configurable privacy mask zones
• Configurable exposure, brightness, saturation, contrast,
sharpness, white balance, WDR, flip and mirror
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 1920x1080, 1280x720, 960 x 540 at up to 30 fps
• 4:3 - 2560x1920, 2048x1536, 1600x1200, 1280x960 at up to 15 fps
Audio Support
• AAC
• G.711
External Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE
• 1 DI / 1 DO
• Reset button
• Video Out (BNC)
• microSD card Slot (SD/SDHC)
• Audio input / output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• ONVIF compliant
• SNMP
Security
• Administrator and user group protection
• Remote client access control
• HTTP and RTSP authentication
• HTTPS encryption for web access
System Requirements for Web Interface
• Browser: Internet Explorer 7 or higher, Firefox, or Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple HTTP, SMTP, and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
OS Support (for setup utility)
• Operating System: Windows 8/7/Vista/XP/2000
D-ViewCamTM System Requirements
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical parameters
Weight
• 1.25 kg for camera only, without sunshield and mounting bracket
Power
• External power adapter: 12 V DC 1.5 A. 50/60 Hz
Power Consumption
• Max:12.48 W Temperature
• Operating: -40 to 50 ̊C
• Storage: -20 to 70 ̊C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• ICES-003
• FCC
• C-Tick
Çözümler
Sipariş Bilgisi
Görseller
DCS-7517/UPAA1
Back view
Front view
Left side view
View from the right
İndir
Destek Merkezi
