DSS-100E-18PEOL EOS
18-Port PoE Unmanaged Surveillance Switch
Tanımlama
The D-Link DSS-100E-18P 18-Port PoE Unmanaged Surveillance Switch with 16 IEEE 802.3at compatible ports, the DSS-100E-18P enables users to easily connect and supply power to PoE-capable devices, such as wireless Access Points (APs), IP cameras, Network Attached Storage (NAS) and IP phones. Your network is at the center of any physical security system, responsible for securely streaming and saving surveillance footage. With robust security, ample network bandwidth and low latency connections, the DSS-100E-18P offers a cost-effective solution to maintain a secure, reliable and compliant surveillance network.
Surveillance-Minded DIP Switch
Effortlessly adjust the DSS-100E-18P operation configuration with a tri-mode DIP switch, conveniently located on the device front panel. D-Link DSS-100E-18P 18-Port PoE Unmanaged Surveillance Switch has three operating modes; Standard, Isolation and Extended modes, each with their own use cases. Standard mode optimally is for connections up to 100 m, supporting 10/100 Mbps per port with priority to ports 1-8 to optimize port cache. Isolation mode prevents port to port communications, permitting ports 1-16 to communicate solely through ports 17-18, where strengthened security measures are implemented. Extended mode utilizes long-reach PoE connections, where ports 9-16 support 250 m connections while ports 1-8 support standard 100 m connections.
Long-Reach PoE Connection
The DSS-100E-18P supports long-range PoE connection configurations, simplifying the issues of distance, power source, and cable deployment for your network systems. Extend connection distances with reduced power transmission loss. Utilize 250 m PoE cable connections at transmission speeds of 10 Mbps. Take advantage of D-Link GE PoE Extenders to power devices up to 650 m away, making the DSS-100E-18P 18-Port PoE Unmanaged Surveillance Switch the ideal choice for deploying PoE devices to your network, no matter your deployment location.
Resilient 6kV Surge Protection
The DSS-100E-18P is equipped with 6kV surge protection, keeping this switch safe against lightning strikes or other power related incidents. This shield prevents PoE devices from electrical damage, ensuring your vital surveillance systems continue functioning, completely uninterrupted. In the event of
an electrical emergency, the DSS-100E-18P will safeguard your cameras, storage devices while keeping your network running, providing reliability and robustness when it counts the most.
Power Over Ethernet IEEE 802.3af/at
The DSS-100E-18P features 16 IEEE 802.3af and IEE 802.3at PoE protocol compatible ports. Each of the PoE ports can supply up to 30 watts, with a total PoE budget of 230 watts, allowing users to attach an IEEE 802.3af or IEEE 802.3at-compliant device to the DSS-100E-18P without requiring additional power. PoE is especially suitable for devices that are far from power outlets or when users want to minimize the clutter of extra cables as power is supplied via the Ethernet cables themselves.
Expand Your Network
The addition of one Gigabit Ethernet port and one GbE/SFP combo uplink port means businesses can increase their network bandwidth using the speed of Gigabit Ethernet while offering redundancy so that voice and surveillance data are transferred reliably. The combo design can increase bandwidth by offering Gigabit copper or fiber connections, giving administrators more options for expansion.
Genel Özellikler
Interface
• 16 x 10/100 Mbps PoE ports
• 1 x 1000Base-T port
• 1 x 100/1000Base-T/SFP combo port
Port Standards & Functions
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3z
• IEEE 802.3af/802.3at
• IEEE 802.3x Flow Control
• Auto MDI/MDIX adjustment for all ports
Performance
Switching Capacity
• 7.2 Gbps
Switching method
• Store and forward
MAC Address Table Size
• 4K Entries
Maximum 64-byte Max.packet Forwarding Rate
• 5.36 Mbps
Packet Buffer
• 2.75 Mbits
LEDs
• Per unit: Power
• Per port: Activity/Link and Speed
• Per PoE port: Power fail, Power OK
PoE Standard
• IEEE 802.3af
• IEEE 802.3at
PoE Capable Ports
• Ports 1~16 up to 30 watts per port
PoE Power Budget
• 230 watts
Physical/Environmental
Surge Protection
• Ports 1~18 up to 6 kV
MTBF (Hours)
• 30 000 hours
Heat Dissipation
• Power On (Standby, no PD device connected):
  • AC input: 33.4 BTU/h
• Maximum:
  • AC input: 885.3 BTU/h
Power Input
• Internal AC input: 100 ~ 240 V
Power Consumption
• Maximum Power Consumption: 265 watts (PoE on), 16.89 watts (PoE off)
• Standby Power Consumption: 9.63 watts / 240 V
Dimensions (W x D x H)
• 440 mm x 178 mm x 44 mm
Weight
• 2.137 kg
Ventilation
• 1 Fan
Operating Temperature
• 0 to 40 В°C
Storage Temperature
• -40 to 70 В°C
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
Certificates
• CE, RoHS, C-Tick, FCC
Safety
• LVD, UL, CB
Çözümler
Sipariş Bilgisi
DSS-100E-18P/A1 18-Port PoE Unmanaged Surveillance Switch
Görseller
DSS-100E-18P/A1
Front view
View from the right
Back view
İndir
Destek Merkezi
