DES-1100-06MPEOL EOS
Custom layer 2 switch with 4 ports 10/100Base-TX PoE ports and 2 10/100/1000Base-T
Tanımlama
Switch DES-1100-06MP equipped with a 4-port 10/100Base-TX PoE and 2 10/100/1000Base-t Switch DES-1100-06MP supports advanced management and security and is a complete solution for small and medium businesses. Power over Ethernet 4 ports DES-1100-06MP support the IEEE 802.3 at PoE. Each PoE port supplies power up to 30 watts with total budget of 80 W switch that allows users to connect to the DES-1100-06MP devices compatible with the 802.3 at standard. This allows you to place equipment in tight spaces, regardless of the location of electrical outlets and to minimize cabling. If the device does not support PoE, use the AC adapter DKT-50, which separates data and power coming over an Ethernet cable from the PoE switch. Advanced level 2 Switch DES-1100-06MP supports a full set of layer 2 features, including Port Mirroring, Spanning Tree and Link Aggregation Control Protocol (LACP). Flow control IEEE 802.3 x allows you to prevent data loss by alerting customers about the buffer overflow. The switch supports the cable diagnostics function and feature Loopback Detection. The function of Loopback Detection is used to detect loops and automatically disable the port that detected the loop. High performance Switch DES-1100-06MP supports advanced traffic management and performance. Function of bandwidth control allows network administrators to define the maximum bandwidth for each port and set the limit of incoming/outgoing traffic increments of up to 512 kbit/s IEEE 802.1 p Quality of Service (QoS) provides traffic classification in real time into 8 priority levels mapped to two queues. Network security Switch DES-1100-06MP supports 802.1 Q VLAN and VLAN port-based. Function protection against storm necessary to restrict to a given threshold of broadcast, multicast or unknown unicast traffic. Switch blocks or drops packets subject to this limitation, since a large amount of such traffic can lead to network congestion. Management Using the Web management interface and SmartConsole utility allows administrators to remotely control their network down to the port level. The SmartConsole utility supports automatic detection and display switches the D-Link Web Smart, belonging to the same L2 network segment. The Web interface provides access to the switch from anywhere on the network without the need to enter IP addresses or subnet mask that allows you to perform setup and basic installation of found devices, including password changes and firmware upgrades.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DES-1100-06MP/A
Front view
View from the right
Back view
İndir
Destek Merkezi
