DIR-100/FEOL EOS
Ethernet broadband router
Apraksts
High permormance
The D-Link DIR-100 broadband router is designed to let a group of users share a broadband Internet connection through a DSL or cable modem. Easy to setup and operate, this router is ideal for novice home and small offce users creating their frst networks.
Quality of service (QoS)
The DIR-100 provides prioritized transmission and reception of VoIP and on-line packets to/from the Internet to enable a group of users to experience the beneft of smooth network connection of inbound and outbound data without concern of traffc congestion. This QoS support allows users to enjoy high broadband transmission for applications such as Internet phones, multimedia and games over the Internet.
Total network security
The DIR-100 router provides frewall protection for network computers again Internet DoS and virus attacks. It flters packets to screen access control based on port and source/destination MAC/IP addresses. With Port Forwarding, the router can be set up to allow separate FTP and multiple games to share the same Internet-visible IP address while still protecting servers and workstations from hackers. Users can set up a home or offce web site by confguring any of the built-in LAN ports to function as a DMZ port. Parental Control allows parents and network administrators to flter out undesired URL web sites, block domains and control the time of day of the use of Internet through scheduling.
Īpašības
WAN INTERFACE
+  1 Small Form-factor Pluggable(SFP) port  for 10/100Mbps Fiber Connecter
+  Supports DSL and cable modem connection
+  Supports “Always-on” (bridged) and PPPoE for PPP connection on demand
LAN INTERFACES
+  4 10/100BASE-TX Ethernet ports
+  Support auto MDI/MDIX
+  Support 802.3x fow control (full-duplex) and back pressure (half-duplex)
VPN SUPPORT
+  PPTP pass-through
+  IPSec pass-through
+  L2TP pass-through
INTERNET GATEWAY FUNCTIONS
+  Network Address Translation (NAT)
+  DHCP server (for automatic IP assignment)
USER ACCESS CONTROL
+  MAC address fltering
+  IP address fltering
+  Scheduling
FIREWALL
+  NAT (Network Address Translation) with VPN pass-through
+  SPI (Stateful Packet Inspection)
QUALITY OF SERVICE
+  Prioritized transmission/reception for VoIP traffc and streaming media
+  Multicast stream IGMP (Internet Group Management Protocol)
CONFIGURATION & MANAGEMENT
+  Quick Installation Wizard
+  Remote Management via Telnet
+  Web-based using Internet Explorer v.6 or Netscape Navigator v.7 or other Java-enable browsers
+  Dynamic Domain Name System (DDNS)
+  Universal Plug and Play (UPnP) compliant
+  Network Time Protocol (NTP) support
FIRMWARE UPGRADE
HTTP (through web browser)
DIAGNOSTIC LEDS
+  Power/Status
+  SFP (Link/Activity)
+  1, 2, 3, 4 LAN ports (Link/Activity)
Sertifikāti
Informācija pasūtījumam
DIR-100/F   Ethernet broadband router
Attēli
DIR-100/F/F
View from the right
Back view
Pārlādēt
Skatiet arī
