DWA-182EOL EOS
מתאם אלחוטי USB3.0 בתקן אלחוטי AC1200
תאור
Wireless Dual Band USB-adapter AC1200 DWA-182 allows you to connect a desktop or notebook computer to a wireless network. Simply install the adapter into an available USB-port and connect to the wireless network to gain access to a secure high-speed Internet connection in the 2.4 GHz band (300 Mbit / s) or 5 GHz (up to 867 Mbit / s) 1. In addition, dual-band operation reduces noise Wi-Fi to increase capacity and, therefore, improve the speed of streaming data, run games and VoIP-telephony.
Bandwidth without interference
Adapter DWA-182 provides for a home network interference-free bandwidth through the use of technology in the two frequency bands. Check email and visit the Web-sites can be in the 2.4 GHz band, and playing online games, to call on Skype and watch streaming HD video - interference-free 5 GHz band.
Easy setup with one click
Support for Wireless Protected Setup (WPS) allows you to quickly and easily set up a secure connection to the wireless network. State of the art encryption technology ensures the safety of data transferred in the network and prevents unauthorized access. To connect the touch of a button.
Compatible with all wireless devices
Adapter DWA-182 supports the latest standard 802.11ac, is backward-compatible with all existing wireless devices. Therefore there is no need to perform updates or using additional adapters.
Standard 802.11ac
802.11ac - this is a new wireless standard for high speed data transmission in the 5 GHz band. Because of this, guaranteed no distortions or delays in the transmission of streaming HD video, video calling, VoIP-telephony work or play. The adapter DWA-182 is backward compatible with all existing wireless 802.11n/g/b devices.
מאפיינים כללים
LED diagnostics
• Activity
Safety
• Wi-Fi Protected Access (WPA ™ and WPA2 ™)
• Wi-Fi Protected Setup - PIN and PBC
Standards
• IEEE 802.11ac (Draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
Type of antenna
flush antenna
Requirements
• Operating system: Windows 7/Vista/XP SP3
• Compatible Web-browsers: Internet Explorer ® v7 or Mozilla Firefox ® v3.0
• Interface: available USB-port
תקנים
הורדות
איורים
DWA-182/Ax
מראה מקדימה
מראה מימין
מראה מימין
דף מידע
ראה גם
