DES-7206-BaseEOL EOS
מארז 6 סלוטים מודולרי אנטרפרייז LAN / MAN ,כולל ספק כח 1200W ויחידת אוורור, עד 192Gbps
תאור
The DES-7200 series super high-density multi-service IPV6 core routing switch can provide the most powerful standalone data process capacity and overall security precaution system. It provides the distributed service convergence platform and abundant LAN and WAN interfaces, to meet more advanced requirement of the network for the performance, security and service in future.
KEY FEATURES
  • Designed for Enterprise LAN and MAN
  • Superior Performance
  • Flexible Modular Design
  • QoS & Bandwidth Management
  • Versatile Management
  • Robust Security
  • High Resiliency
מאפיינים כללים
L2 Features:
 MAC Address Table
 DES-7206: up to 64K
 ARP
 Static ARP
 Configurable ARP aging time
 Jumbo Frame up to 9,216 Bytes
 IGMP snooping
 1K Groups
 Spanning Tree
 802.1D STP
 802.1w RSTP
 802.1s MSTP
 Rapid Ether Ring Protection (RERP)
 Support up to 16 domains
 Recovering L2 traffic in 500ms
 Rapid Link Detection Protocol (RLDP)
 802.3ad Link Aggregation
 128 Trunk Groups, 8 Ports Per Group
 Port Mirroring:
 One-to-One
 Multi-to-One
 Tx/Rx/Both port mirroring
 Head of Line Blocking Prevention
VLAN:
 802.1Q Tagged VLAN
 802.1v
 VLAN Group: 4K
 Configurable VLAN ID: 1-4094
 Port-Based VLAN
 Super VLAN
 Private VLAN
 Double VLAN (Q-in-Q)
 Port-Based Q-in-Q
 Selective Q-in-Q
L3 Features:
 Max 2K IP interface
 Secondary IP
 VRRP
 IPv6 Tunneling
 Manual Tunnel
 ISATAP
 6to4
 IPv6 Ready Phase 2
L3 Routing:
 Floating Static Routes: 1000
 Static Routes: Max. 1000
 Policy Based Route
 Multi Path Route:
 ECMP /WCMP
 RIP v1/v2
 RIPng (Ipv6)
 OSPF
 OSPF v2
 OSPF v3 (Ipv6)
 Stub/NSSA Area
 BGP+ v4 (Ipv6)
L3 Multicasting:
 PIM-DM
 PIM-DM v6 *
 PIM-SM
 PIM-SM v6*
 PIM-SSM+ PIM-SSM v6*
 IGMP v1/v2/v3
QoS (Quality of Service):
 802.1p Class of Service (CoS)
 8 queues
 Queue Handling:
 Strict
 Weighted Round Robin (WRR)
 ST+WRR
 CoS Based on:
 VLAN ID
 802.1p Priority
 MAC Address
 IP Address or IP Prefix
 DSCP/IP Precedence
 IP Protocol Type
 TCP/UDP Port
 Combination of above
 Support Following Actions for Flows
 Remark 802.1p Priority Tag
 Remark ToS/DSCP Priority Tag
 Rate Limiting
 Congestion Control
 Flow Statistic
 Bandwidth Control
 For Egress traffic, min. Granularity 64Kbps)
 For Ingress traffic, min. Granularity 64Kbps)+ Time Based QoS
MPLS (ASE required):
 MPLS
 MPLS Label Management
 LDP
 MPLS L3 VPN (MPLS / BGP VPN)
 MPLS L2 VPN+ VPLS*
ACL (Access Control List)
 Up to 2K Rules per line card
 ACL Based on
 802.1p Priority
 VLAN ID
 MAC Address
 DSCP/IP Precedence
 IP Protocol Type
 TCP/UDP Port Number
 Combination of the above
 Time-based ACL
Security:
 CPU Protection Policy (CPP)
 SSH
 Port Security up to 16 MAC address per port
 Global MAC-IP Binding
 Defeat IP Scan
 IP-MAC-Port Binding
AAA:
 802.1X
 Port-Based Access Control
 MAC-Based Access Control
 Dynamic VLAN Assignment
 Accounting
 Period Accounting
 Multiple Accounting
 RADIUS
Management:
 Command Line Interface (CLI)
 Telnet Server
 TFTP
 Xmodem
 SNMP v1/v2c/v3
 SNMP Trap
 System Log
 RMON v1
 Support 1,2,3,9 Groups
 DNS Client
 Debug
 NTP/SNTP
 File System
 Flash storage media
 Multiple Firmware
 Multiple Configuration
 System Status LED
 System Alert
MIB/IETF Standard:
 RFC1213 MIB-II
 RFC1493 Bridge MIB
 RFC1901, 1907 SNMPv2 MIB
 RFC1157, 2571~2576 SNMP MIB
 RFC1271, 2819 RMON MIB
 RFC3569 PIM-SSM MIB
 D-Link Private MIB
 RFC2362 PIM-SM
 RFC2338, 2787 VRRP
 RFC1075 DVMRP
 RFC2474~2475 DiffServ
 RFC2674 802.1P
 RFC2138~2139, 2865~2866  RADIUS
 RFC1370, 1587, 1765, 2328, 2370 OSPF
 RFC1771, 1997, 2439, 2796, 2842, 2918 BGP
 RFC1542, 2131, 3046 DHCP
 RFC3069 Super VLAN
 RFC3411~3417 SNMP
 RFC768 UDP
 RFC791 IP
 RFC793 TCP
 RFC854 Telnet
 RFC1305 NTP
 RFC1350 TFTP
 RFC1769 SNTP
Warranty
Lifetime Warranty
תקנים
הורדות
איורים
DES-7206-Base/A
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
