DES-3200-18EOL EOS
מתג Metro מנוהל מתקדם עם 16 פורטים במהירות 10/100Mbps, יציאה אחת ג'יגהביט/אופטי (SFP) ויציאה אחת משולבת ג'יגהביט/אופטי (SFP)
תאור
The DES-3200 switches is a line of managed switches D-Link 2-level, intended for networks Metro Ethernet (ETTX and FTTX) and corporate networks. Switches in this series are equipped with 8/16/24/48 ports 10/100 Mbit / s Fast Ethernet, and a combo port 1/2/4 Gigabit Ethernet / SFP. Switches DES-3200-10 / 18 made in the case of 9/11 inches wide and equipped with a passive cooling system, suitable for desktop use and for use in telecommunication and control cabinets. Switches DES-3200-26,28,28 / ME, 28F, 52 1U height designed for installation in 19-inch rack and provides a connection for copper or optics (24/48 port) at a speed of 100 Mbit / c. All devices have a series of practical design with 1, 2 or 4-port combo Gigabit Ethernet / SFP, which provide bandwidth of up to 4 Gbit / s and allow to use these switches in a ring topology. Switch DES-3200-28 / ME is made specifically for use in telecommunication closets where operators and engineers have access only to the front of the device and need quick troubleshooting. All interfaces are located on the front of the DES-3200-28 / ME, including the connector for the power cable that meets the requirements of large networks. In addition, the switch DES-3200-28 / ME is equipped with a connector "dry contacts" for event detection and alarm. DES-3200-28F is the ideal solution for network deployment FTTX, allowing you to bring fiber line directly to the subscriber unit. By using the switch DES-3200-28F fiber-optic lines to connect subscribers greatly increased transmission distance (20 km) and excludes the impact of crosstalk inherent in copper cable. Switches DES-3200-28P / 52P meet the standards of PoE (Power over Ethernet-cable) IEEE 802.3af and IEEE 802.3at and provide power up to 15.4 watts per port and up to 30 watts on the first four / eight ports. Supports PoE / PoE + devices such as video / IP-phones, wireless access points and IP-cameras, allowing them to supply power directly from a switch on the Ethernet-cable, which greatly simplifies network deployment. All switches DES-3200 series are equipped with 2 or 4 ports of Gigabit SFP, which provides the ability to select the type of network topology, "ring", "tree" or mixed type.
Safety and reliability
Switches DES-3200 series supports access control 802.1x port-based / host, the ability to create a guest VLAN, and authentication and RADIUS / TACACS / XTACACS / TACACS + when connected to a switch. Function IP-MAC-Port Binding allows administrators to bind IP-addresses and MAC addresses of the user to determine the port number on the switch, thereby prohibiting the user to change the network settings. Moreover, thanks to the DHCP Snooping, the switch automatically detects pairs of IP / MAC-addresses issued by the server, DHCP-tracking packages and storing them in a "white list" IMPB. These features play a significant role in keeping the network secure. Built-in D-Link Safeguard Engine identifies and prioritization of packets to be processed directly by the CPU of the switch, in order to prevent malicious attacks and neutralize the effects of spurious traffic on the CPU switch. In addition, DES-3200 supports List for access control (ACL). This functionality enables administrators to restrict access to network services and does not affect the performance of the switch.
Resilience / performance
Switches DES-3200 series supports protocols 802.1D-2004 edition, 802.1w and 802.1s Multiple Spanning Tree (MSTP). STP allows you to organize data backup route used in the event of failure of any switch on the main route of the network traffic. The switches also support link aggregation, standards-based 802.3ad (LACP) and 802.1AX, which allows you to combine multiple ports into groups, increasing the bandwidth and increasing the resilience of connections between network devices. The switches support 802.1p for Quality of Service (QoS). In addition, the traffic can be prioritized on the basis of marks TOS, DSCP, MAC-addresses or IP-address of the client, Vlan number, port number, TCP / UDP, protocol type, or based on the contents of the package defined by the user. This functionality is especially important in the provision of IPTV. Also, The DES-3200 series supports the functionality of Voice VLAN, is a separate vlan, which is automatically placed in the voice traffic, with a view to its subsequent processing with a higher priority level than the rest of the traffic.
Traffic Control and Bandwidth
Bandwidth control allows network administrators to define bandwidth per port increments up to 8 kbit / s for incoming and outgoing traffic. The switches also support the functional protection from the storm (Storm Control), which allows you to get rid of unnecessary broadcast / multicast traffic. Port Mirroring facilitate traffic diagnostics and helps administrators to monitor the network performance. Switches DES-3200 series supports markers "Two speed, three-colored marking" and "One speed three color labeling" (trTCM / srTCM), allowing flow splitting by prioritizing to ensure maximum throughput of important traffic.
Multicasting
Switches DES-3200 series supports a full feature set for L2 multicast, including IGMP Snooping, IGMP filtering, Fast Leave. With the support of the functional Switch The DES-3200 provides an opportunity to work with IPTV-services, enjoys a growing demand in the market.
IGMP / MLD Snooping allows host-based connection of multiple customer multicast group to a single network interface. When you use the ISM VLAN multicast traffic for efficient bandwidth consumption is transmitted in a separate Vlan. ISM VLAN profiles allow users to quickly and easily assign / change the preset settings on ports multicast subscribers.
OAM
Switches DES-3200 series supports a cable diagnostic function to check the status of network cables and identify the causes of malfunction of the cable. Function 802.1ag Connectivity Fault Management (CFM) provides tools for surveillance, as well as for troubleshooting in complex Ethernet-networks, allowing service providers to perform the test compound, and quickly locate network problems, identify users, faced with these problems. Options 802.3ah Ethernet OAM, Dying Gasp, and D-Link Unidirectional Link Detection (DULD) can improve network manageability and enhance stability of the compound, as well as to detect the fault.
Control Features
Switches DES-3200 series supports standard management protocols such as SNMP, RMON, Telnet, SSH / SSL. The user-friendly web interface provides easy operation. Automatic, DHCP is an enhanced management feature that allows administrators to pre-configure the settings and save them to a TFTP-server and automatically applied to the switches in the process of obtaining IP-address from the server that makes network configuration easier and faster. Support of LLDP and LLDP-MED can detect used in an Ethernet network equipment. In accordance with the result of the search, the administrator can easily apply the settings to the device discovery and obtain a graphic representation of the topology using the Network Management System (NMS).
Function D-Link Single IP Management (SIM) simplifies and improves the efficiency of management tasks, allowing multiple switches simultaneously setting, surveillance and maintenance from any location using a Web-browser. Moreover, the switch DES-3200 series supports software D-View 6.0. D-View 6.0 is a Network Management System that allows you to improve the most important for the network characteristics such as availability, reliability, fault tolerance and security. D-View 6.0 provides network administrators with a set of useful tools for effective configuration management, performance and security, as well as error detection.
Support for IPv6
Switches DES-3200 series has successfully passed the certification IPv6 Ready Logo Phase 2, which guarantees the operation of the switch in networks IPv6. In addition, this series supports both protocol stacks IPv4 / v6, allowing the switches to act as a bridge between IPv4 and IPv6. With the constant expansion of the network security problem is most acute. To solve a series of DES-3200 supports features such as IPv6 ACL, IMPBv6 and L3 Control Packet Filtering, designed to protect against network attacks in IPv6 networks.
מאפיינים כללים
Flexible Hardware Design
• 8, 16, 24, or 48 10/100BASE-TX ports
• 1 or 2 Combo 1000BASE-T/SFP ports
• 1 or 2 SFP ports
• 9”, 11”, or 19” Rack-mount
• Support 802.3at (PoE+) and 802.3af (PoE) for PoE models
Surge Protection
• All Ethernet ports have 6 KV surge protection
L2 Features
• 802.1D STP, 802.1w RSTP, and 802.1s MSTP
• Loopback Detection
• 802.1AX and 802.3ad Link Aggregation
• Voice VLAN1
Security
• SSH/SSL
• Port Security
• Access Control List (ACL)
• 802.1X / Web-Based (WAC)1/MAC-Based (MAC) Access Control
• Guest VLAN
• IP-MAC-Port Binding (IMPB)
• Traffic Monitoring and Bandwidth Control
• Port Mirroring/Bandwidth Control
• Broadcast/Multicast/Unicast Storm Control
• srTCM, trTCM, & policing
Number of 10/100BASE-TX ports
• DES-3200-10 - 8 ports
• DES-3200-18 - 16 ports
• DES-3200-28 - 24 ports
• DES-3200-28P - 24 ports
• DES-3200-52 - 48 ports
• DES-3200-52P - 48 ports
Number of Combo 1000Base-T/SFP ports
• DES-3200-10 - 1 ports
• DES-3200-18 - 1 ports
• DES-3200-28 - 2 ports
• DES-3200-28P - 2 ports
• DES-3200-52 - 2 ports
• DES-3200-52P - 2 ports
Number of SFP ports
Number of 10/100/1000BASE-T ports
PoE Supported Models (Standard(s)/Number of Ports/Maximum Power Budget)
• DES-3200-28P (802.3af/at/24 ports/188W)
• DES-3200-52P (802.3af/at/48 ports/370W)
RS-232 Console Port
•  Yes
Switch Capacity
• DES-3200-10 - 5.6 Gbps
• DES-3200-18 - 7.2 Gbps
• DES-3200-28 - 12.8 Gbps
• DES-3200-28P - 12.8 Gbps
• DES-3200-52 - 17.6 Gbps
• DES-3200-52P - 17.6 Gbps
64-Byte Packet Forwarding Rate
• DES-3200-10 - 4.2 Mpps
• DES-3200-18 - 5.4 Mpps
• DES-3200-28 - 9.5 Mpps
• DES-3200-28P - 9.5 Mpps
• DES-3200-52 - 13.1 Mpps
• DES-3200-52P - 13.1 Mpps
MAC Address Table Size
• 16K
Packet Buffer
• 1.5 MB
Flash Memory
• 32MB
Stackability
• Virtual Stacking D-Link Single IP Management
• Up to 32 units per Virtual Stack
• MAC address table: 16K
• Flow Control
        802.3x Flow Control
        HOL Blocking Prevention
    Jumbo Frame up to 12K bytes
    Spanning Tree Protocols
        802.1D STP
        802.1w RSTP
        802.1s MSTP
    BPDU Filtering
    Root Restriction
    Loopback Detection
    Link Aggregation
        Complies with 802.1AX and 802.3ad
        DES-3200-10: Max. 5 groups, 8 ports per group
        DES-3200-18: Max. 9 groups, 8 ports per group
        DES-3200-28/28P: Max. 14 groups, 8 ports per group
        DES-3200-52/52P: Max. 26 groups, 8 ports per group
    Port Mirroring:
        Supports 1 Mirroring group
        Supports One-to-One, Many-to-One, Flow-based (ACL) mirroring
        Ethernet Ring Protection Switching (ERPS)
        L2 Protocol Tunneling (L2PT)
L2 Multicasting
    IGMP Snooping:
        IGMP v1/v2 snooping, v3 awareness
        Supports 1024 Groups
        Port/Host-based IGMP snooping Fast Leave
        Report Suppression
    MLD Snooping
        MLD v1, MLD v2 awareness
        Support 1 K groups
        Host-based MLD snooping
        Fast Leave
    IGMP Authentication
    IGMP/MLD Proxy Reporting1
VLAN
    802.1Q Tagged VLAN
    VLAN Group
        Max. 4K VLAN
    Port-based VLAN
    MAC-based VLAN
    GVRP
    802.1v Protocol VLAN
    VLAN Trunking
    Double VLAN (Q-in-Q)
        Port-based Q-in-Q
        Selective Q-in-Q
    ISM VLAN
    VLAN Translation
    Voice VLAN1
L3 Features
    IPv6 Neighbor Discovery (ND)
    Bandwidth Control
        Port-based (Ingress/Egress, Min. Granularity 8 Kbps)
        Flow-based (Ingress/Egress, Min. Granularity 8 Kbps)
        Per egress queue bandwidth control (Min.Granularity 8 Kbps
    8 Queues per Port
    DSCP
    802.1p
    Queue Handling
        Strict Priority
        Weighted Round Robin (WRR)
        Strict + WRR
    Three Color Marker
        trTCM
        srTCM
    CoS Based on:
        Switch port
        802.1p Priority Queues
        VLAN ID
        MAC Address
        Ether type
        TOS
        DSCP Protocol Type
        TCP/UDP Port
        IPv6 Traffic Class
        IPv6 Flow Label
        User-Definited Packet Content
    Supports Following Actions for Flows
        Remark 802.1p Priority Tag
        Remark TOS/DSCP Tag
        Bandwidth Control Flow Statistic
    Up to 1024 ingress access rules
    ACL Based on
        Switch Port
        802.1p Priority
        VLAN ID
        Ether Type
        IPv4/v6 address
        DSCP
        Protocol Type
        TCP/UDP Port Number
        IPv6 Traffic Class
        IPv6 Flow Label
        User-Defined Packet Content
    Time-based ACL
    ACL statistics
    CPU interface filtering
Security
    SSH v1, v2
    SSL v1, v2, v3
    Port Security
    Up to 64 MAC addresses per port
    Traffic Segmentation
    IP-MAC-Port Binding
        ARP Inspection
        IP Inspection
        DHCP Snooping
    DHCP Server Screening
    DHCP Client Filtering
    ARP Spoofing Prevention
    BPDU Attack Protection
    NetBIOS/NetBEUI Filtering
    DoS Attack Prevention
AAA
    802.1X
        Port-based Access Control
        Host-based Access Control
        Dynamic VLAN assignment
    Identity-driven Policy (VLAN, ACL, or QoS) Assignment
    MAC-based Access Control (MAC)
    Web-based Access Control (WAC)1
    Microsoft® NAP(IPv4/v61)
        Support 802.1X NAP
        Support DHCP NAP
    Guest VLAN
    RADIUS Accounting
    RADIUS (IPv4/v61)
    TACACS
    TACACS+
    XTACACS+
    Trusted Host
OAM
    Cable Diagnostics
    802.3ah Ethernet Link OAM
    Dying Gasp 802.1ag Connectivity Fault Management (CFM)
    802.3ah D-Link extension: D-Link Unidirectional Link Detection (DULD)
Green
    D-Link Green 3.0: Power saving function
        LED Shut-Off1
        Port Shut-Off1
        System Hibernation1
    Power Saving by Time-based PoE
Management
    Web-based GUI (IPv4)
    Command Line Interface (CLI)
    Telnet Server/ Client (IPv4)
    TFTP Client (IPv4)
    FTP Client (IPv4)
    Zmodem
    Command Logging
    SNMP v1/v2c/v3
    SNMP Traps
    System Log
    RMON v1
        Supports 1,2,3,9 Groups
    RMON v2
        Supports ProbeConfig Group
    LLDP
    802.1AB
    LLDP-MED1
    BootP/DHCP Client
    DHCP Auto-Configuration
    DHCP Relay (IPv4)
    DHCP Relay Option 12
    DHCP Relay Option 82
    PPPoE Circult-ID Tag Insertion
    Flash File System
    SNTP
    CPU Monitoring
    Memory Monitoring
    Debug Command
    Password Encryption
    Password Recovery
    Microsoft® NLB (Network Load Balancing) Support
    Ping (IPv4/v61)
    Traceroute
    Multiple IP Interface
MIB
    RFC RFC1065, 1066, 1155, 1156, 2578 MIB Structure
    RFC 1212 Concise MIB Definitions
    RFC1213 MIB II
    RFC 1215 MIB Traps Convention
    RFC1493, 4188 Bridge MIB
    RFC1157, 2571-2576 SNMP MIB
    RFC1901-1908, 3418,3636, 1442,2578 SNMPv2 MIB
    RFC271,1757, 2819 RMON MIB
    RFC 2465 IPv6 MIB
    RFC 2466 ICMPv6 MIB
    RFC 2737 Entity MIB
    RFC 4293 IPv6 SNMP Mgmt Interface MIB
    Private MIB
    RFC 3289 DIFFSERV MIB
    RFC2021 RMONv2 MIB
    RFC1398, 1643, 1650, 2358, 2665, 3635 Ether-like MIB
    RFC2668 802.3 MAU MIB
    RFC2674,4363 802.1p MIB
    RFC 2233, 2863 IF MIB
    RFC 2618 RADIUS Authentication Client MIB
    RFC4022 MIB for TCP
    RFC4113 MIB for UDP
    RFC 3298 MIB for Deffserv.
    RFC2620 RADIUS Accounting Client MIB
    RFC 2925 Ping& Traceroute MIB
    Running configuration write and backup
    TFTP uploads and downloads
    Trap MIB
IETF® Standard
    RFC768 UDP
    RFC791 IP
    RFC792 ICMPv4
    RFC2463, 4443 ICMPv6
    RFC4884 Extended ICMP to Support Multi-Part Messages
    RFC793 TCP RFC 2474, 3260 Definition of the DS Field in the IPv4 and IPv6 Header
    RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
    RFC2571, RFC2572, RFC2573, RFC2574 SNMP
    RFC826 ARP
IPv6
    RFC1981 Path MTU Discovery
    RFC2460 IPv6
    RFC2461, 4861 Neighbor Discovery
    RFC2462, 4862 IPv6 Stateless Address Auto-configuration
    RFC2464 IPv6 Neighbor over Ethernet and definition
    RFC3513, 4291 IPv6 Addressing Architecture
    RFC2893, 4213 IPv4/IPv6 dual stack function
תקנים
הורדות
איורים
DES-3200-18/A
מראה מקדימה
מראה מימין
מראה מאחורה
DES-3200-18/C
מראה מקדימה
מראה מימין
מראה מאחורה
DES-3200-18/DC/C
מראה מקדימה
מראה מימין
מראה מאחורה
DES-3200-18/RPS/C
מראה מקדימה
מראה מימין
מראה מאחורה
DES-3200-18/UPS/C
מראה מקדימה
מראה מימין
מראה מאחורה
DES-3200-18/B
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
