DCS-3110EOL EOS
Securicam Network megapiksel IP-kaamera PoE ja mobiiltelefoni 3G video toetusega
Kirjeldus
DESIGNED FOR POWERFUL SURVEILLANCE
The DCS-3110 Megapixel Network Camera is designed for business use. A 1.3 Megapixel progressive scan CMOS sensor enables capture of high-resolution images on a wide coverage area, making it suitable for sensitive motion detection as an indoor/outdoor security solution. The DCS-3110 uses its SoC (system-on-chip) to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. Furthermore, this camera supports MPEG4 multicast streaming, letting users view content by subscribing to a multicast IP address on the network. The DCS-3110 can also be connected to a variety of external devices such as IR-sensors, switches and alarm relays making it an ideal solution for high quality viewing and reliable recording during the day or night.
WATCH LIVE VIDEOS FROM A 3G DEVICE
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Users are offered a fexible and convenient way to remotely monitor a home or offce in real time, anywhere within the 3GPP service area.
EASY TO SETUP WITH WIRED PoE ACCESS
For effective surveillance in and around a building, the DCS-3110 comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module for fexible deployment. It can connect directly to a PoE Ethernet switch without the need for a power cable, providing users the freedom to place the camera anywhere they want, including high walls and hard to see locations.
SMART & EASY TO USE
D-Link’s D-ViewCam software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts and be instantly informed of unusual activities. In addition, this network camera supports the universal plug-n-play feature, which allows computers running on Windows 2000/xP/Vista to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g.mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
1 Camera must be connected to a multicast-enabled router
Põhiomadused
Võrguprotokollide toetus
IPV4, TCP/IP, RTSP/ RTP/ RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPNP, DDNS, PPPOE, IGMP, SAMBA-klient, IP filtreerimine, 3GPP
Võrguliidesed
+ IEEE 802.3/802.3u Ethernet 10/100BASE-TX port
+ Pooldupleks/täisdupleks režiimide toetus
+ Voojuhtimine IEEE 802.3x täisdupleksrežiimi jaoks
+ IEEE 802.3af PoE toetus
Video algoritmide toetus
+ Stop kaadrite salvestamine JPEG formaadis
+ MJPEG ja MPEG-4 formaati kompressmine
+ Heli kahepoolne edastamine (dual-streaming)
+ MPEG-4 UDP, TCP või HTTP peale
+ MJPEG HTTP peale
Video resolutsioon
+ MJPEG video lahenduvusega kuni 1280x1024 (1,3 Mpiksel)
+ MPEG-4 video lahenduvusega kuni 640x480 (VGA)
+ 176 x 144 - kuni 30 kaadrit/s
+ 320 x 240 - kuni 30 kaadrit/s
+ 640 x 480 - kuni 30 kaadrit/s
+ 1280х1024 – kuni 8 kaadrit/s
Video funktsionaalsus
+ Pildi kvaliteedi, suuruse ja edastuskiiruse häälestamine Настройка
+ Teksti- ja ajammärgised
+ 3 akent liikumise tuvastamise häälestamiseks
+ Objekti pildi pööramine ja peegeldamine
+ Pildi heleduse häälestamine
+ Automaatne võimenduse reguleerimine (AGC), automaatne valget värvi reguleerimine (AWB), Ekspositsiooni automaatne häälestamine (AES)
Video edastuskiirus
20 Kbit/s – 4 Мbit/s
Sensori ja objektiivi spetsifikatsioonid
+ 1/4-tolli 1,3 Mpiksline progressiivne värviline CMOS-sensor
+ 6 mm megapiksline objektiiv, F1,6
+ Eemaldatav infrapuna filter: automaatne/graafiku järgi/käsitsi
+ Minimaalne valgustatus: 1,5 lux, F2.0
Sündmuste juhtimine
+ Igapäevane ajakava liikumise tuvastamiseks
+ Sündmustest teatamine ja piltide/video alla laadimine kasutades HTTP, SMTP või FTP
+ Mitmete HTTP-, SMTP- või FTP-serverite häälestamise võimalus
+ Sündmustest teatamise paindlikud seaded
+ Mitmete salvestamismeetodite kasutamine lihtsustab kopeerimise protsessi
Turvalisus
+ Administraatori ja kasutaja gruppide kaitsmine
+ Autentimine
+ HTTP ja RTSP digitaalne krüpteerimine
Videojälgimise funktsioonid
+ Kaugjuhtimine/kontroll: kuni 32 kaamerat
+ 32 kaameratest piltide vaatamine ühelt ekraanilt
+ Kõikide juhtimisfunktsioonide toetus veebiliidese kaudu
+ Video salvestamise optsioon liikumisanduri käivitamisel või käsitsi
Kaugjuhtimine
+ Häälestamine veebiliidese kaudu
+ Piltide/video saamine ja salvestamine CF kaardile, võrguketta massiivile või lokaalsele kõvakettale veebibrauseri kaudu
+ Live Video vaatamine: kuni 10 klienti*
Nõuded süsteemile
+ Operatsioonisüsteemid: Microsoft Windows 2000, ХP, Vista
+ Web-brauser: Internet Explorer, Firefox, Netscape, Mozilla, Opera
ЗGPP mobiilne videojälgimine
Mobiiltelefon 3GPP mängijaga mis toetab:
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
Audio
+ Kompressimine ja edastuskiirus:
- Kõne kompressimine (GCM-AMR), edastuskiirus: 4,75 Kbit/s – 12,2 Kbit/s
- Audio kodeerimine (MPEG-4, AAC), edastuskiirus: 16 Kbit/s – 128 Kbit/s
+ Liides: sisseehitatud mikrofon, ühenduspesa välisele mikrofonile ja kõlaritele
+ SIP-protokolli toetus (kahepoolne infovahetus)
+ Heli väljalülitamise riist-ja tarkvaraline toetus
Välised liidesed
+ D/I -liides ja D/O –liides välise anduri ja signalisatsiooni jaoks
+ RS-485 liides välise skänneri jaoks
+ 12 V alalisvoolu väljund
Indikaatorid
2-värviline indikaator
Andmete salvestamine
CF kaardipesa MP4 failide lokaalse salvestamiseks
Pakendi sisu
+ Kaamera DCS-3110
+ Väline toiteadapter
+ Kaamera alus
+ Еthernet-kaabel cat5
+ Kiirpaigaldusjuhend
+ СD-paat kasutusjuhendiga
Sertifikaadid
Sidustooted
Pildid
DCS-3110
Eestvaade
Eestvaade
Eestvaade
Tagantvaade
Failid
Vaadake samuti
