DSL-2750U/RAEOL EOS
Wireless ADSL2+ Router with 3G/LTE/Ethernet WAN Support and USB Port
Tanımlama
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
ADSL Port and 4-port Switch, Ethernet WAN Support
The router is equipped with an ADSL port to connect to an ADSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
Wireless Interface
You are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n.
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, and the WPS function.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Security
The wireless router DSL-2750U includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DSL-2750U via the user-friendly web-based interface (the interface is available in several languages).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Genel Özellikler
DSL-2750U/RA/U3
DSL-2750U/RA/U2
Hardware
Interfaces
RJ-11 ADSL port
4 10/100BASE-TX LAN ports
USB 2.0 port
LEDs
POWER
4 LAN LEDs
WLAN
WPS
USB
DSL
INTERNET
POWER
DSL
INTERNET
WLAN
4 LAN LEDs
WPS
USB
Buttons
ON/OFF button to power on/power off
RESET button to restore factory default settings
WPS button to set up secure wireless connection
WIRELESS ON/OFF button to enable/disable wireless network
WPS/WLAN button to set up secure wireless connection and enable/disable wireless network
Antenna
Two external non-detachable omnidirectional antennas (5dBi gain)
Two internal omnidirectional antennas (2dBi gain)
MIMO
2 x 2
Power connector
Power input connector (DC)
DSL Parameters
ADSL Standards
ADSL
Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
ADSL2
ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
ADSL2+
ITU-T G.992.5 Annex A/L/M
ATM/PPP Protocols
Bridged and routed Ethernet encapsulation
VC-based or LLC-based multiplexing
ATM Forum UNI3.1/4.0 PVC
(up to 8 PVCs)
ATM Adaptation Layer Type 5 (AAL5)
ITU-T I.610 OAM F4/F5 loopback
ATM QoS
PPP over ATM (RFC 2364)
PPP over Ethernet (PPPoE)
Keep-alive for PPP connections
Software
WAN connection types
LTE
3G
PPPoA
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
IPoA
Static IP / Dynamic IP
Static IPv6 / Dynamic IPv6
Bridge
Network functions
DHCP server/relay
DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
DNS relay
Support of DNSv6 AAAA records
Dynamic DNS
Static IP routing
Static IPv6 routing
IGMP Proxy
IGMP snooping
RIP
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IP filter
IPv6 filter
MAC filter
URL filter
DMZ
Prevention of ARP attacks
Prevention of DDoS attacks
Virtual servers
Built-in Yandex.DNS web content filtering service
VPN
PPTP/PPPoE pass-through
IPSec/PPTP/L2TP/PPPoE pass-through
QoS
Interface grouping
VLAN priority (802.1p)
Traffic classification/prioritization for Ethernet WAN (upstream traffic only)
USB interface functions
USB modem
Auto connection to available type of supported network (4G/3G/2G)
4G/3G/2G1
Enabling/disabling PIN code check, changing PIN code2
USB storage
File browser
Print server
Access to storage via accounts
Built-in Samba server
Built-in FTP server
Built-in DLNA server
Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management
Local and remote access to settings through TELNET/WEB (HTTP)
Multilingual web-based interface for configuration and management
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration
to/from file
Support of remote logging
Automatic synchronization of system time with NTP server and manual time/date setup
Ping utility
TR-069 client
Wireless Module Parameters
Standards
IEEE 802.11b/g/n
Frequency range
2400 ~ 2483.5MHz
Wireless connection security
WEP
WPA/WPA2 (Personal)
МАС filter
WPS (PBC/PIN)
Advanced functions
Information on connected Wi-Fi clients
Advanced settings
Wireless connection rate
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
802.11b
15dBm
16.5 ~ 18.5dBm
802.11g
13.5 ~ 15dBm
13.5 ~ 16.5dBm
802.11n
13.5 ~ 15dBm
13.5 ~ 16.5dBm
Receiver sensitivity
802.11b
-84dBm
-85dBm at 1Mbps
-83dBm at 2Mbps
-81dBm at 5.5Mbps
-79dBm at 11Mbps
802.11g
-72dBm
-85dBm at 6Mbps
-84dBm at 9Mbps
-82dBm at 12Mbps
-80dBm at 18Mbps
-77dBm at 24Mbps
-73dBm at 36Mbps
-69dBm at 48Mbps
-68dBm at 54Mbps
802.11n
HT20
-70dBm
HT40
-67dBm
HT20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
HT40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
Modulation schemes
802.11b
CCK (11, 5.5Mbps), DQPSK (2Mbps), DBPSK (1Mbps), DSSS
802.11g
PSK/CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
802.11n
PSK/CCK, DBPSK, DQPSK, OFDM, etc.
Physical Parameters
Dimensions (L x W x H)
174 x 119 x 32 mm (6.6 x 4.7 x 1.3 in)
160 x 59 x 120 mm (6.3 x 2.3 x 4.7 in)
Weight
197 g (0.43 lb)
240 g (0.53 lb)
Operating Environment
Power
Output: 12V DC, 1A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 70 °C
Humidity
From 5% to 95% (non-condensing)
Delivery Package
Router DSL-2750U
Power adapter DC 12V/1A
RJ-11 telephone cable
Ethernet cable
Splitter
“Quick Installation Guide” (brochure)
Supported USB Modems3
GSM
Alcatel X500
D-Link DWM-152C1
D-Link DWM-156A6
D-Link DWM-156A7
D-Link DWM-156C1
D-Link DWM-157B1
D-Link DWM-157B1 (Velcom)
D-Link DWM-158D1
Huawei E150
Huawei E1550
Huawei E156G
Huawei E160G
Huawei E169G
Huawei E171
Huawei E173 (Megafon)
Huawei E220
Huawei E352 (Megafon)
ZTE MF112
ZTE MF192
ZTE MF626
ZTE MF627
ZTE MF652
ZTE MF667
ZTE MF668
ZTE MF752
CDMA
Airplus MCD-650
Airplus MCD-800
AnyDATA ADU-300A
AnyDATA ADU-500A
AnyDATA ADU-510A
Huawei EC306
ZTE AC5710
ZTE AC5730
LTE
Huawei E3131
Huawei E3272
Huawei E367
Huawei E392
Megafon M100-1
Megafon M100-3
Megafon M100-4
Megafon M150-1
MTS 824F
Yota LU-150
Yota WLTUBA-107
ZTE MF823
ZTE MF827
1For LTE and GSM USB modems.
2For GSM USB modems only.
3The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Çözümler
Sipariş Bilgisi
DSL-2750U/RA/U3   Wireless ADSL2+ Router with 3G/LTE/Ethernet WAN Support and USB Port
DSL-2750U/RA/U2   Wireless ADSL2+ Router with 3G/LTE/Ethernet WAN Support and USB Port
Görseller
DSL-2750U/RA/U2
Back view
View from the right
Front view
İndir
Destek Merkezi
