Hızlı Arama
Ürün Özellikleri:
VoIP-FXS-portu ve 4-port switch ile kablosuz yönlendirici
Genel Özellikler:
Fiziksel Özellikler
Hardware
WAN interface
1 10/100BASE-TX Ethernet port for cable or DSL-modem or connect to a dedicated Ethernet-line
LAN interface
4 порта 10/100BASE-TX Ethernet
WLAN interface
• IEEE 802.11n (до 300 Мбит / с)
• IEEE 802.11b / g
FXS interface
1 FXS port to connect an analog phone or fax machine
Frequency band
• 802.11b: 2400 ~ 2484 МГц в диапазоне Spit
• 802.11g: 2400 ~ 2484 МГц в диапазоне Spit
• 802.11n
  ◦ HT20: 2400 ~ 2483.5 MGts in range ISM
  ◦ HT40: 2422 ~ 2452 MGts in range ISM
Speed ​​Wireless
• 802.11b: 11, 5.5, 2 and 1 Mbit / c for each channel, with automatic speed
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s for each channel, with automatic speed
• 802.11n
  ◦ HT20: up to 150 Mbit / s
  ◦ HT40: up to 300 Mbit / s
Modulation Schemes
• 802.11b: CCK, DQPSK, DBPSK
• 802.11g: 64QAM, 16QAM, QPSK, BPSK, DSSS
• 802.11n: 64 QAM, 16QAM, QPSK, BPSK
Software
Basic functions SIP
• Invite with Challenge
• Register for IP-address SIP-server or domain name
• Support the format of SIP URI (RFC3986)
• Support for outbound (outbound) proxy
• Таймеры сессий (update/re-invite)
• Support for DNS SRV
• Types of calls: Voice / Modem / Fax
• User-configurable dial plan (dial plan)
• Identify the source and destination (P2P-calls) manually
• Dialing E.164 (with an exclusion rule ENUM)
Call Functions
• Direct call IP-to-IP without SIP proxy
• Hold / resume a call
• Call Waiting
• Forwarding (unconditional, on busy, no answer)
• "Do not disturb"
• Message Waiting Indication (MWI)
• Lock Hidden Numbers
• AntiAON
• Speed ​​Dial
• «hotline"
Voice Features
• Кодеки: G.711 a / μ-law, G.729A, G.726, G.722
• DTMF detection and generation
• Comfort noise generation (CNG)
• Voice Activity Detection (VAD)
• Variable (dynamic) jitter-buffer
• Generation of call progress tone (FXS)
• Program Gain
• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
• Support for tone / pulse dialing
• Detection and generation Caller ID (Caller ID)
• T.30 FAX bypass по G.711, T.38 Real Time FAX Relay
Network Features
• Types of WAN-connections:
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ PPTP/L2TP
  ◦ PPTP/L2TP + Static IP
  ◦ PPTP/L2TP + Dynamic IP
• DHCP server and DHCP client
• DNS relay
• Skipping a VPN tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• VLAN support
• Supports ping from the external network (WAN ping respond)
Wireless connection
• Supported safety standards:
  ◦ WEP
  ◦ WPA/WPA2 Personal
  ◦ WPA/WPA2 Enterprise
• MAC-фильтр
• Methods PIN and WPS PBC function
• Функция WMM (Wi-Fi QoS)
• Advanced Settings
Firewall Features
• IP-filters
• MAC-фильтр
• URL-фильтр
• DMZ-зона
• Function of ARP-zashtitы and DDoS-Attack
• Virtual servers
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Access the TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• Функция ping
• Утилита traceroute
Physical Properties
Indicators
• POWER
• WAN
• 4 LAN indicator
• WLAN
• WPS
• FXS
Power
• Power supply: External Power Adapter DC 12V/1.25A
• Power on / off
• The RESET button to return to the factory defaults
• Кнопка WPS
• Power on / off the wireless network
Operating temperature
От 0 до 40 C
Storage temperature
-20 To 70 ° C
Operating Humidity
From 10% to 90% non-condensing
Storage humidity
From 5% to 95% non-condensing
Ürünler | Destek  | Haberler  | Hakkında |
