Ürün Özellikleri:
2-port Internet Server for SOHO Networks EOL |
Tanımlama:
Share ISP Accounts Share Modems
Analog and ISDN Support Cost-saving Dial-on-Demand
The device’s dial-on-demand function allows your network to establish a line connection when needed without requiring users’ intervention. Using inactivity timer, the device disconnects the line when there is no traffic. It re-connects the line when traffic flow is again detected. Easy Configuration
Setting up the device for running is easy. You can select to administer the Internet server in-band through a Windows- based program, through Telnet, or through a web browser. Current setting and operational status can be displayed for monitoring and control purposes. Auto-sensing 10/100Mbps LAN Port
Network connection is through an 10/100Mbps dual-speed port that supports both Ethernet and Fast Ethernet. The port auto-detects the network speed and adjusts to use the correct one completely without user’s need to configure.
Destek Merkezi
