Hızlı Arama
Ürün Özellikleri:
WIRELESS 108 g ROUTER
EOL
Tanımlama:
ENHANCED WIRELESS PERFORMANCE
Create a fast and secure wireless network for your home using the D-Link Wireless 108 g Router with wireless speeds of up to 108Mbps. Share your high-speed Internet connection with multiple users and start sharing files, music, and photos.
BASIC SECURITY PROTECTION
The D-Link Wireless 108 g Router includes a built-in firewall that safeguards your network from harmful attacks. It minimizes the threats of hackers and prevents unwanted intruders from entering your network. Additional security features like MAC address filtering prevents unauthorized network access and parental control features prevent children from viewing inappropriate content. The Wireless 108 g Router also supports WEP and WPA encryption. D-Link’s easy-to-use Wireless 108 g Router includes basic routing and security features to help you create a simple wireless network for your office or home.
COMPATIBILITY ASSURANCE
The D-Link Wireless 108 g Router is based on the 802.11g standard and is backward compatible with 802.11b, ensuring compatibility with a wide range of Router is based on the 802.11g standard and is backward compatible with 802.11b, ensuring compatibility with a wide range of  is based on the 802.11g standard and is backward compatible with 802.11b, ensuring compatibility with a wide range of  wireless devices. The Wireless 108 g Router includes four Ethernet ports ready for you to connect Ethernet-enabled PCs, print servers and other devices.
EASY TO INSTALL AND USE
With D-Link’s Quick Router Setup Wizard, you can set up your wireless network in minutes. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. It configures your Internet Service Provider (ISP) settings to quickly establish broadband Internet connectivity. The Wizard even makes it easy to add new wireless devices onto the network.
Ürünler | Destek  | Haberler  | Hakkında |
