Hızlı Arama
Ürün Özellikleri:
Wireless N150 Router
EOL
Genel Özellikler:
Hardware
Interfaces
• 10/100BASE-TX WAN port
• 4 10/100BASE-TX LAN ports
LEDs
• POWER
• INTERNET
• WLAN
• 4 LAN LEDs
• WPS
Buttons
• RESET button to restore factory default settings
• WPS button to set up secure wireless connection
Antenna
• External detachable omnidirectional antenna (2dBi gain)
Power connector
• Power input connector (DC)
Software
WAN connection types
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP / Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• DHCP server/relay
• DNS relay
• Dynamic DNS
• Static IP routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• Manual speed and duplex mode setup for each Ethernet port
• Flow control
Firewall functions
• IP filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
Management
• Local and remote access to settings through TELNET/WEB (HTTP)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping utility
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Managing connected stations
• Advanced settings
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 150Mbps (from MCS0 to MCS7)
Transmitter output power
• 802.11b (typical at room temperature 25 °C)
17dBm (+/-2dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
17dBm (+/-2dB) at 6, 9, 12, 18, 24, 36Mbps
16dBm (+/-2dB) at 48Mbps
15dBm (+/-2dB) at 54Mbps
• 802.11n (typical at room temperature 25 °C)
16dBm (+/-2dB) at MCS0/1/2
15dBm (+/-2dB) at MCS3/4
13dBm (+/-2dB) at MCS5/7
Receiver sensitivity
• 802.11b (typical at PER = 8% at room temperature 25 °C)
-90dBm at 1Mbps
-88dBm at 2Mbps
-87dBm at 5.5Mbps
-86dBm at 11Mbps
• 802.11g (typical at PER = 10% at room temperature 25 °C)
-84dBm at 6Mbps
-82dBm at 9Mbps
-80dBm at 12Mbps
-78dBm at 18Mbps
-77dBm at 24Mbps
-74dBm at 36Mbps
-70dBm at 48Mbps
-68dBm at 54Mbps
• 802.11n (typical at PER = 10% at room temperature 25 °C)
HT20
-93dBm at MCS0
-90dBm at MCS1
-88dBm at MCS2
-85dBm at MCS3
-82dBm at MCS4
-78dBm at MCS5
-77dBm at MCS6
-76dBm at MCS7
HT40
-90dBm at MCS0
-87dBm at MCS1
-85dBm at MCS2
-82dBm at MCS3
-79dBm at MCS4
-75dBm at MCS5
-74dBm at MCS6
-73dBm at MCS7
Modulation schemes
• 802.11b: DQPSK, DBPSK, CCK
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Physical Parameters
Dimensions
• 113.2 x 147.5 x 31.5 mm (4.5 x 5.8 x 1.2 in)
Weight
• 246 g (0.54 lb)
Operating Environment
Power
• Output: 5V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-300NRU
• Power adapter DC 5V/1A
• Ethernet cable
Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
