DWR-921EOL EOS
4G LTE desteği ile kablosuz yönlendirici
Tanımlama
Wireless router with support for 4G LTE DWR-921 allows users to get mobile broadband access to the Internet anywhere. After the connection is established, users can transfer files, streaming media data and send SMS-messages. Simply insert the USIM-card and organize public access to Internet connection 3G / 4G via a secure wireless network, or using any of the four ports Ethernet 10/100 Mbit / s.
High-speed mobile connection
DWR-921 provides high-speed mobile connection 3G / 4G at a rate of receiving data up to 100 Mbit / s and a data rate up to 50 Mbit / s, which enables you to view Web-pages, streaming video and music over the Internet to your computer or mobile device.
Secure wired and wireless connections
DWR-921 is equipped with double firewall (SPI and NAT) to prevent potential attacks from across the Internet. Encryption WPA / WPA2 protects the wireless network that allows you to organize securely share the connection 3G / 4G, without fear that the network will have access to unauthorized users.
Easy to set up and use
Wireless router with support for 4G LTE DWR-921 can be quickly and easily installed almost anywhere. This unit is ideal for use when you need to quickly set up a wireless network in areas where access is not available. DWR-921 can be installed even in buses, trains or boats, allowing passengers to check e-mail or chat online while traveling.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DWR-921
Back view
Front view
İndir
Destek Merkezi
