Hızlı Arama
Ürün Özellikleri:
Wireless Dual-Band N600 Router with Gigabit Ethernet ports
Genel Özellikler:
Fiziksel Özellikler
Hardware
Interfaces
• WAN: 1 10/100/1000BASE-TX Ethernet port for cable or DSL-modem or a dedicated Ethernet-line
• LAN: 4 ports 10/100/1000BASE-TX Ethernet
• WLAN:
  IEEE 802.11n (600 Mbit / s *)
  IEEE 802.11a/b/g
The USB interface
USB 2.0 type A to connect the USB-modem, printer or storage device
Frequency band
• 802.11a: 5725 ~ 5850 MHz ISM band
• 802.11b: 2400 ~ 2483.5 MHz ISM band
• 802.11g: 2400 ~ 2483.5 MHz ISM band
• 802.11n:
  ◦ 2400 ~ 2483.5 MHz ISM band
  ◦ 5725 ~ 5850 MHz ISM band
Wireless speed
• 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / c
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11n:
  2.4 GHz: MCS0 ~ MCS15 (up to 300 Mbit / s)
  5 GHz: MCS0 ~ MCS15 (up to 300 Mbit / s)
Modulation Schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Receiver Sensitivity
• 802.11a (typical at PER = 10% for a packet size of 1000 bytes at room temperature 25 ° C)
  -65 DBm at 54 Mbps / c
• 802.11b (typical at PER = 8% for the packet size of 1000 bytes at room temperature 25 ° C)
  -82 DBm at 1 Mbit / s
  -78 DBm at 5.5 Mbit / s
  -76 DBm at 11 Mbit / s
• 802.11g (typical at PER = 10% for a packet size of 1000 bytes at room temperature 25 ° C)
  -82 DBm at 6 Mbit / c
  -81 DBm at 9 Mbit / c
  -79 DBm at 12 Mbps / c
  -77 DBm at 18 Mbps / c
  -74 DBm at 24 Mbps / c
  -70 DBm at 36 Mbps / c
  -66 DBm at 48 Mbps / c
• 802.11n (typical at PER = 10% for a packet size of 1000 bytes)
  HT20
  -82 DBm at MCS0 / 8
  -79 DBm @ MCS1 / 9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -70 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -64 DBm at MCS7/15
  HT40
  -79 DBm at MCS0 / 8
  -76 DBm @ MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -63 DBm at MCS5/13
  -62 DBm at MCS6/14
  -61 DBm at MCS7/15
The output power of the transmitter
• 802.11a (typically at ambient temperature of 25 ° C)
  12.5 dBm (+ / -1.5 dB)
• 802.11b (typical at room temperature 25 ° C)
  17 dBm (+ / -1.5 dB)
• 802.11g (typical at room temperature 25 ° C)
  14.5 dBm (+ / -1.5 dB)
• 802.11n (typical at room temperature 25 ° C)
  HT20
  14 dBm (+ / -1.5 dB) at MCS6 / 7 (2.4 GHz)
  11.5 dBm (+ / -1.5 dB) at MCS6 / 7 (5 GHz)
  HT40
Software
Network Features
• The types of WAN-connection:
 ◦ LTE
 ◦ 3G
 ◦ PPPoE
 ◦ Static IP
 ◦ Dynamic IP
 ◦ PPTP/L2TP
 ◦ PPTP/L2TP + Static IP
 ◦ PPTP/L2TP + Dynamic IP
• DHCP-server and DHCP-Client
• DNS relay
• Skip VPN-tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote Access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• VLAN support
• Flow control (flow control)
• TR-069 Client
• Supports ping from the external network (WAN ping respond)
USB-modem
• Automatically connect to an available type of supported network (4G/3G/2G)
• Turn on / off check PIN-code, PIN-code change **
USB-drive
• Access via SMB
• Built-in FTP-server
• Print Server
• Accounts for access to storage
Wireless connection
• Supports security standards:
 ◦ WEP
 ◦ WPA/WPA2 Personal
 ◦ WPA/WPA2 Enterprise
• MAC-filter
• Control of the connected devices
• Methods and PIN WPS PBC function
• The WMM (Wi-Fi QoS)
• Advanced Settings
• Supports the "client"
Torrent-client
The ability to download files to a USB-drive and with it
Firewall Security
• IP-filters
• MAC-filter
• URL-Filter
• DMZ-zone
• The Prevention of ARP-and DDoS-attacks
• Virtual Servers
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually set the date and time
• The ping
• The traceroute utility
Supported USB-modems ***
• GSM-modems
 ◦ D-Link DWM-152
 ◦ D-Link DWM-156
 ◦ Huawei E1550
 ◦ Huawei E160G
 ◦ Huawei E169G
 ◦ Huawei E171
 ◦ Huawei E220
 ◦ ZTE MF112
 ◦ ZTE MF192
 ◦ ZTE MF626
 ◦ ZTE MF627
 ◦ ZTE MF652
 ◦ ZTE MF668
 ◦ ZTE MF752
• CDMA-modem
 ◦ Airplus MCD-650
 ◦ Airplus MCD-800
 ◦ AnyDATA ADU-300A
 ◦ AnyDATA ADU-500A
 ◦ AnyDATA ADU-510A
 ◦ ZTE AC5710
 ◦ ZTE AC5730
• LTE-modems
 ◦ Huawei E392
 ◦ Yota LU150
• WiMAX-modem
 ◦ Samsung SWC-U200 (software version: u200_rev1-2.7.40-CI14)
Fiziksel Özellikler
Indicators
• Power
• WPS
• INTERNET
• 2.4GHz
• 5GHz
• 4 LEDs LAN
• USB
Nutrition
• Power supply: External Power Supply DC 12V / 1.2A
• Power on / off
• The RESET button to restore factory default settings
• WPS Button
Operating temperature
From 0 to 40 C
Storage temperature
-20 To 65 ° C
Operating humidity
From 10% to 90% non-condensing
Storage humidity
From 5% to 95% non-condensing
* Up to 300 Mbit / s in the 2.4 GHz and up to 300 Mbit / s in the 5 GHz band
** Only for GSM USB-modems.
*** The manufacturer does not guarantee the operation of the router with every modification of the USB-modems.
Ürünler | Destek  | Haberler  | Hakkında |
