Hızlı Arama
Ürün Özellikleri:
Broadband wireless router VPN-Cloud, and 300 Mbit / s
Tanımlama:
Wireless VPN-Router DIR-640L, which combines the functions of a router, switch, 10/100, 802.11n wireless access point and firewall designed for networking sector SOHO, requiring maximum performance and security. In the small business environment increases the demand for construction of networks, and thus enterprises are interested in the device, providing protection for the network. Purchase of Wireless VPN-Router DIR-640L is a profitable investment, as the device supports security features, easy configuration mechanisms and provides maximum protection for the network of small offices and homes.
User-friendly interface
DIR-640L offers a user-friendly intuitive Web-based interface for configuration. Manage settings available to the user as an administrator or with the rights of Read / Write. Thanks to the data access privileges, any authorized user can configure or access the management interface DIR-640L.
The service mydlink network management
Broadband VPN-router supports Cloud service mydlink Cloud, which allows the user to access the network, regardless of its location. With a computer connected to the Internet or a mobile device equipped with iOS or Android, you can use the view of clients connected to the router, change settings, or block access to the individual clients. Home users can check the most frequently visited Internet sites their children, and for the offices the ability to monitor network activity of workers.
Enterprise-class protection
DIR-640L performs the secure transmission of data over wireless networks using encryption WPA ™ or WPA2 ™. In addition, the protection of the network from intruders and potential attacks by using a firewall that uses the mechanisms of Network Address Translation (NAT) and Stateful Packet Inspection (SPI).
Advanced hardware features
DIR-640L can be connected to a cable or DSL-modem for high-speed public Internet access. Also, the device is equipped with a 4-port 10/100 Mbit / s, which supports full duplex mode, allowing you to connect up to 4 devices with interfaces Ethernet. To extend a wired network, you need to simply add additional switches. In addition, using DIR-640L, you can create a virtual private network (VPN) and provide secure remote access to a central network through the Internet for 25 simultaneous users.
VPN Performance
For optimal VPN configuration, the router DIR-640L is equipped with a built-in VPN-client and the VPN-server, allowing you to maintain most of the required policies VPN. In this device, VPN support is implemented in hardware and manage up to 25 profiles, VPN. DIR-640L supports protocols IPSec, PPTP, L2TP and GRE in server mode, and allows you to handle the traffic pass-through. Advanced VPN configuration options include encryption with DES, the key management IKE / ISAKMP, negotiation mode Main / Aggressive and authentication support VPN, using a database of 10 internal users.
Ürünler | Destek  | Haberler  | Hakkında |
