DIR-620/D1EOL EOS
802.11n Wireless Router with built-in 4-port switch and a port USB, with network support 3G/CDMA/WiMAX
Tanımlama
Wireless Interface
Using the multifunction wireless router DIR-620, you can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network from virtually anywhere (in the range of a wireless network). The Router can serve as a base station for a wireless network device of the standards 802.11b, 802.11g and 802.11n (at speeds up to 300 Mbit / s). In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Configuration and Management
To manage and configure a generic wireless router DIR-620 uses a simple and user-friendly web-based interface (available in several languages).
USB-port
The router is equipped with a USB-port for connection of USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router, USB-drive, which will be used as a network drive, or a printer.
4-Port Switch
Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network.
Safety
Universal Wireless Router DIR-620 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DIR-620/D1D1
Front view
Back view
İndir
Destek Merkezi
